program quits after loading of a helicopter
BuzzFace
Post by BuzzFace »
Hello all,
Since my german insn't all that good, ill do this in english..
After starting Heli-X, i select a lanscape, then a helicopter.
5 seconds after loading the heli, the program quits.
It makes a log file, stated below.
Can any1 help me out?
It runs on a brandnew Dell laptop, specs also stated below.
Thanx!
# An unexpected error has been detected by Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x2705f9d0, pid=2428, tid=3936
# Java VM: Java HotSpot(TM) Client VM (1.6.0_03-b05 mixed mode)
# Problematic frame:
# C [ig4icd32.dll+0x2f9d0]
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
--------------- T H R E A D ---------------
Current thread (0x16f8cc00): JavaThread "AWT-EventQueue-0" [_thread_in_native, id=3936]
siginfo: ExceptionCode=0xc0000005, reading address 0x0a74c989
Registers:
EAX=0x0a74c985, EBX=0x00000000, ECX=0x373552d8, EDX=0x00000018
ESP=0x175df41c, EBP=0x175df458, ESI=0x00000018, EDI=0x000003fd
EIP=0x2705f9d0, EFLAGS=0x00210202
Top of Stack: (sp=0x175df41c)
0x175df41c: 00000018 0014d9e8 2705fa13 00000018
0x175df42c: 00000000 0014d9e8 13390a30 2705fb14
0x175df43c: 00000018 16f8cc00 13390a30 175eb075
0x175df44c: 00008892 00000018 2704f1c0 175df49c
0x175df45c: 0091a440 16f8ccec 175df4bc 00008892
0x175df46c: 00000018 2704f1c0 00000000 00000002
0x175df47c: 175df47c 00000000 175df4bc 13442ca8
0x175df48c: 00000000 13390a30 00000000 175df4ac
Instructions: (pc=0x2705f9d0)
0x2705f9c0: f7 8b 41 0c 8b 04 90 85 c0 74 10 eb 03 8d 49 00
0x2705f9d0: 39 70 04 74 0d 8b 00 85 c0 75 f5 5f 33 c0 5e c2
Stack: [0x17590000,0x175e0000), sp=0x175df41c, free space=317k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
j com.sun.opengl.impl.GLImpl.dispatch_glBindBufferARB0(IIJ)V+0
j com.sun.opengl.impl.GLImpl.glBindBufferARB(II)V+31
j org.xith3d.render.jsr231.ShapeAtomPeer.bindGeometryComponent(Ljavax/media/opengl/GL;Lorg/xith3d/render/RenderPeer;Lorg/xith3d/render/RenderOptions;Lorg/xith3d/scenegraph/GeomData;IIZ)V+114
j org.xith3d.render.jsr231.ShapeAtomPeer.setupBuffers(Lorg/xith3d/render/RenderPeer;Lorg/xith3d/render/RenderOptions;Ljavax/media/opengl/GL;Lorg/xith3d/scenegraph/GeometryArray;Z)V+25
j org.xith3d.render.jsr231.ShapeAtomPeer.drawGeometry(Lorg/xith3d/render/RenderPeer;Lorg/xith3d/render/RenderOptions;Ljavax/media/opengl/GL;Lorg/xith3d/scenegraph/GeometryArray;Z)I+323
j org.xith3d.render.jsr231.ShapeAtomPeer.render(Ljavax/media/opengl/GL;Lorg/xith3d/render/prerender/ShapeAtom;Lorg/xith3d/scenegraph/Appearance;Lorg/xith3d/scenegraph/Geometry;Lorg/xith3d/scenegraph/GeometryArray;ZZZZZZLorg/xith3d/render/RenderPeer;Lorg/xith3d/render/RenderOptions;Z)I+602
j org.xith3d.render.jsr231.ShapeAtomPeer.renderAtom(Lorg/xith3d/render/RenderPeer;Lorg/xith3d/render/RenderOptions;Lorg/xith3d/render/prerender/RenderAtom;JJLorg/xith3d/render/RenderPeer$RenderMode;J)I+749
J org.xith3d.render.RenderPeer.renderAtom(Lorg/xith3d/render/RenderOptions;Lorg/xith3d/render/prerender/RenderAtom;Lorg/xith3d/scenegraph/View;JJJLorg/xith3d/render/RenderPeer$RenderMode;)I
j org.xith3d.render.jsr231.RenderPeerImpl.drawBin(Ljavax/media/opengl/GL;Lorg/xith3d/render/RenderOptions;ZZLorg/xith3d/render/prerender/RenderBin;Lorg/xith3d/scenegraph/View;Lorg/openmali/spatial/bodies/Frustum;JIJJLorg/xith3d/render/RenderPeer$RenderMode;)I+81
j org.xith3d.render.jsr231.RenderPeerImpl.renderMain(Ljavax/media/opengl/GL;Lorg/xith3d/render/RenderOptions;ZZLorg/xith3d/scenegraph/View;Lorg/openmali/spatial/bodies/Frustum;Lorg/xith3d/render/RenderPass;Lorg/openmali/vecmath2/Matrix3f;JIJJLorg/xith3d/render/RenderPeer$RenderMode;)I+84
j org.xith3d.render.jsr231.RenderPeerImpl.renderRenderPass(Ljava/lang/Object;Ljava/util/List;Lorg/xith3d/render/RenderPass;IZLorg/xith3d/render/RenderPeer$RenderMode;Lorg/xith3d/scenegraph/View;ZJJJLorg/xith3d/picking/PickRequest;I)I+577
j org.xith3d.render.jsr231.RenderPeerImpl.render(Ljava/lang/Object;Lorg/xith3d/scenegraph/View;Lorg/xith3d/render/prerender/BackgroundCache;Ljava/util/List;ZJJJLorg/xith3d/picking/PickRequest;)Ljava/lang/Object;+215
j org.xith3d.render.jsr231.CanvasPeerImplBase.doRender(Lorg/xith3d/scenegraph/View;Lorg/xith3d/render/prerender/BackgroundCache;Ljava/util/List;ZJJJLorg/xith3d/picking/PickRequest;)Ljava/lang/Object;+21
j org.xith3d.render.jsr231.CanvasPeerImplAWT.display(Ljavax/media/opengl/GLAutoDrawable;)V+201
j com.sun.opengl.impl.GLDrawableHelper.display(Ljavax/media/opengl/GLAutoDrawable;)V+29
j javax.media.opengl.GLCanvas$DisplayAction.run()V+80
j com.sun.opengl.impl.GLDrawableHelper.invokeGL(Ljavax/media/opengl/GLDrawable;Ljavax/media/opengl/GLContext;Ljava/lang/Runnable;Ljava/lang/Runnable;)V+418
j javax.media.opengl.GLCanvas$DisplayOnEventDispatchThreadAction.run()V+35
j java.awt.event.InvocationEvent.dispatch()V+11
j java.awt.EventQueue.dispatchEvent(Ljava/awt/AWTEvent;)V+26
j java.awt.EventDispatchThread.pumpOneEventForFilters(I)Z+156
j java.awt.EventDispatchThread.pumpEventsForFilter(ILjava/awt/Conditional;Ljava/awt/EventFilter;)V+30
j java.awt.EventDispatchThread.pumpEventsForHierarchy(ILjava/awt/Conditional;Ljava/awt/Component;)V+11
j java.awt.EventDispatchThread.pumpEvents(ILjava/awt/Conditional;)V+4
j java.awt.EventDispatchThread.pumpEvents(Ljava/awt/Conditional;)V+3
j java.awt.EventDispatchThread.run()V+9
v ~StubRoutines::call_stub
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x1fbf5400 JavaThread "TimerQueue" daemon [_thread_blocked, id=2880]
0x1fddfc00 JavaThread "Xith3D render thread" [_thread_blocked, id=4084]
0x1fce4400 JavaThread "Thread-4" daemon [_thread_in_native, id=2104]
0x002a6800 JavaThread "DestroyJavaVM" [_thread_blocked, id=764]
=>0x16f8cc00 JavaThread "AWT-EventQueue-0" [_thread_in_native, id=3936]
0x16f3e000 JavaThread "AWT-Windows" daemon [_thread_in_native, id=3084]
0x16f3d400 JavaThread "AWT-Shutdown" [_thread_blocked, id=3260]
0x16f0f800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=2312]
0x16b7c000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=3824]
0x16b77400 JavaThread "CompilerThread0" daemon [_thread_blocked, id=3972]
0x16b76000 JavaThread "Attach Listener" daemon [_thread_blocked, id=4020]
0x16b75400 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=3876]
0x16b67400 JavaThread "Finalizer" daemon [_thread_blocked, id=2464]
0x16b63000 JavaThread "Reference Handler" daemon [_thread_blocked, id=2044]
Other Threads:
0x16b5e400 VMThread [id=2028]
0x16b86800 WatcherThread [id=2416]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 2944K, used 1891K [0x02990000, 0x02cc0000, 0x03d40000)
eden space 2624K, 72% used [0x02990000, 0x02b68e40, 0x02c20000)
from space 320K, 0% used [0x02c70000, 0x02c70000, 0x02cc0000)
to space 320K, 0% used [0x02c20000, 0x02c20000, 0x02c70000)
tenured generation total 38552K, used 31014K [0x03d40000, 0x062e6000, 0x12990000)
the space 38552K, 80% used [0x03d40000, 0x05b89a18, 0x05b89c00, 0x062e6000)
compacting perm gen total 17152K, used 17028K [0x12990000, 0x13a50000, 0x16990000)
the space 17152K, 99% used [0x12990000, 0x13a31370, 0x13a31400, 0x13a50000)
No shared spaces configured.
Dynamic libraries:
0x00400000 - 0x00423000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\java.exe
0x7c900000 - 0x7c9b5000 C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c900000 C:\WINDOWS\system32\kernel32.dll
0x77f40000 - 0x77feb000 C:\WINDOWS\system32\ADVAPI32.dll
0x77da0000 - 0x77e32000 C:\WINDOWS\system32\RPCRT4.dll
0x77f10000 - 0x77f21000 C:\WINDOWS\system32\Secur32.dll
0x7c340000 - 0x7c396000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\msvcr71.dll
0x6d7c0000 - 0x6da0a000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\client\jvm.dll
0x7e390000 - 0x7e421000 C:\WINDOWS\system32\USER32.dll
0x77e40000 - 0x77e89000 C:\WINDOWS\system32\GDI32.dll
0x76af0000 - 0x76b1e000 C:\WINDOWS\system32\WINMM.dll
0x76330000 - 0x7634d000 C:\WINDOWS\system32\IMM32.DLL
0x6d310000 - 0x6d318000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\hpi.dll
0x76bb0000 - 0x76bbb000 C:\WINDOWS\system32\PSAPI.DLL
0x6d770000 - 0x6d77c000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\verify.dll
0x6d3b0000 - 0x6d3cf000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\java.dll
0x6d7b0000 - 0x6d7bf000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\zip.dll
0x6d000000 - 0x6d1c3000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\awt.dll
0x72f70000 - 0x72f96000 C:\WINDOWS\system32\WINSPOOL.DRV
0x77be0000 - 0x77c38000 C:\WINDOWS\system32\msvcrt.dll
0x774a0000 - 0x775dd000 C:\WINDOWS\system32\ole32.dll
0x746a0000 - 0x746ec000 C:\WINDOWS\system32\MSCTF.dll
0x75250000 - 0x7527e000 C:\WINDOWS\system32\msctfime.ime
0x7c9c0000 - 0x7d1e2000 C:\WINDOWS\system32\shell32.dll
0x77e90000 - 0x77f06000 C:\WINDOWS\system32\SHLWAPI.dll
0x77390000 - 0x77493000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll
0x5d4e0000 - 0x5d57a000 C:\WINDOWS\system32\comctl32.dll
0x6d2b0000 - 0x6d303000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\fontmanager.dll
0x6d570000 - 0x6d583000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\net.dll
0x71a30000 - 0x71a47000 C:\WINDOWS\system32\WS2_32.dll
0x71a20000 - 0x71a28000 C:\WINDOWS\system32\WS2HELP.dll
0x6d590000 - 0x6d599000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\nio.dll
0x6d450000 - 0x6d474000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\jpeg.dll
0x6d220000 - 0x6d243000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\dcpr.dll
0x175e0000 - 0x1762d000 C:\fms\heli-x-windows\HELI-X\libs\jogl\windows-i586\jogl.dll
0x5f160000 - 0x5f22c000 C:\WINDOWS\system32\OPENGL32.dll
0x5f400000 - 0x5f421000 C:\WINDOWS\system32\GLU32.dll
0x736d0000 - 0x7371b000 C:\WINDOWS\system32\DDRAW.dll
0x73b30000 - 0x73b36000 C:\WINDOWS\system32\DCIMAN32.dll
0x17660000 - 0x1766b000 C:\fms\heli-x-windows\HELI-X\libs\joal\windows-i586\joal_native.dll
0x17670000 - 0x17675000 C:\fms\heli-x-windows\HELI-X\libs\gluegen\windows-i586\gluegen-rt.dll
0x17680000 - 0x178a5000 C:\fms\heli-x-windows\HELI-X\libs\joal\windows-i586\OpenAL32.dll
0x76f90000 - 0x7700f000 C:\WINDOWS\system32\CLBCATQ.DLL
0x77010000 - 0x770dd000 C:\WINDOWS\system32\COMRes.dll
0x770e0000 - 0x7716b000 C:\WINDOWS\system32\OLEAUT32.dll
0x77bd0000 - 0x77bd8000 C:\WINDOWS\system32\VERSION.dll
0x73e80000 - 0x73edc000 C:\WINDOWS\system32\dsound.dll
0x76bf0000 - 0x76c1e000 C:\WINDOWS\system32\WINTRUST.dll
0x77a40000 - 0x77ad6000 C:\WINDOWS\system32\CRYPT32.dll
0x77ae0000 - 0x77af2000 C:\WINDOWS\system32\MSASN1.dll
0x76c50000 - 0x76c78000 C:\WINDOWS\system32\IMAGEHLP.dll
0x72c90000 - 0x72c99000 C:\WINDOWS\system32\wdmaud.drv
0x72c80000 - 0x72c88000 C:\WINDOWS\system32\msacm32.drv
0x77bb0000 - 0x77bc5000 C:\WINDOWS\system32\MSACM32.dll
0x77ba0000 - 0x77ba7000 C:\WINDOWS\system32\midimap.dll
0x73e50000 - 0x73e54000 C:\WINDOWS\system32\KsUser.dll
0x209b0000 - 0x209c6000 C:\fms\heli-x-windows\HELI-X\libs\jinput\windows-i586\jinput-dx8.dll
0x6d320000 - 0x6d359000 C:\WINDOWS\system32\DINPUT8.dll
0x68db0000 - 0x68db9000 C:\WINDOWS\system32\HID.DLL
0x778e0000 - 0x779d7000 C:\WINDOWS\system32\SETUPAPI.DLL
0x20a40000 - 0x20a56000 C:\fms\heli-x-windows\HELI-X\libs\jinput\windows-i586\jinput-raw.dll
0x6d1f0000 - 0x6d21f000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\cmm.dll
0x20bc0000 - 0x20e95000 C:\WINDOWS\system32\xpsp2res.dll
0x6d3e0000 - 0x6d3e6000 C:\fms\heli-x-windows\HELI-X\Java\jre1.6.0_03\bin\jawt.dll
0x171f0000 - 0x171f5000 C:\fms\heli-x-windows\HELI-X\libs\jogl\windows-i586\jogl_awt.dll
0x27030000 - 0x2727e000 C:\WINDOWS\system32\ig4icd32.dll
0x27310000 - 0x2748c000 C:\WINDOWS\system32\ig4dev32.dll
VM Arguments:
jvm_args: -Dsun.java2d.noddraw=true -Djava.library.path=./libs;./libs/gluegen/windows-i586;./libs/jinput/windows-i586;./libs/jogl/windows-i586;./libs/lwjgl/windows-i586;./libs/joal/windows-i586 -Xmx256m
java_command: ch.ntb.HeliX.application.Application
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Common Files\Roxio Shared\DLLShared\;C:\Program Files\Common Files\Roxio Shared\9.0\DLLShared\
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 6 Model 15 Stepping 11, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Service Pack 3
CPU:total 2 (2 cores per cpu, 1 threads per core) family 6 model 15 stepping 11, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3
Memory: 4k page, physical 1038632k(227432k free), swap 2499884k(1762148k free)
vm_info: Java HotSpot(TM) Client VM (1.6.0_03-b05) for windows-x86, built on Sep 24 2007 22:24:33 by "java_re" with unknown MS VC++:1310
Re: program quits after loading of a helicopter
english is welcome here, no problem.
Please try the following:
1. Update your graphics driver to the newest version.
2. Set the color depth of the desktop to 16 bit.
2. Delete all files in files/controller
3. Delete files/Application/ApplicationSettings.xml
4. Start HELI-X
5. Configure the controller BEFORE you load a heli
6. Try the airport "small".
7. How many FPS are shown in the title bar?
8. Load a helicopter.
Let's see what happens.
What is your grapics adapter? How much memory?
BuzzFace
Post by BuzzFace »
Hi Micheal,
Thanks for the help, ill try these options, ill get back to it on sunday.
unfortunatly the driver is the most recent, its an Mobile Intel® GM965 Express Chipset
(on normal settings the framerate is around 200pbs or even higher when the sreensize is lowered..)
greetz, BuzzFace
BuzzFace
Post by BuzzFace »
Hi again Michael,
still doesnt work as its supposed to do..
Framerate with the small airport is above 200, 115 with a normal airport.
i do see all the graphics, untill i load the heli.
did all the mods you suggested, still no change..
any other suggestions?
(coz the program is very very good once it works.. (as on my other pc))
many thanks in advance!
greetz, Buzzface
Since the program works with the airports it does not seem to be an issue of the memory. I see the following possibilities:
1. Look at the settings of your OS and the graphics adapter if there is a possibility for tuning
2. Try to downgrade the graphics driver. HELI-X needs only openGL 1.3 and not the newest openGL features. Perhaps there is a feature not implemented in a compatible way in the driver.
