HobbyKing Wireless 9 in 1 Simulator Adapter
Mgfiest
Post by Mgfiest »
Have you guys thought of adding this unit to be used with this software.
http://hobbyking.com/hobbyking/store/__ ... 9%20in%201
Thanks
Re: HobbyKing Wireless 9 in 1 Simulator Adapter
Have you tested it?
Mgfiest
Post by Mgfiest »
if you are asking me ... if I tested.. . nope... this is a suggestion threat... so I suggested... they are the developers aren't they... I was hoping someone else has tried...
Post by JS1 »
Guess that adapter is known to developer, but to be listed as recommended interface it needs to be successfully tested first. As there is a ton of cables and adapters out there with even more combinations counting the radios in, testing them has to rely on user experiences - hence the question whether you have tested it... Anyway, thanks for bringing this adapter to attention in case someone can share his experience. Could be interesting indeed!
