Heli-x help
Bahuras
Heli-x help
Post by Bahuras »
Hello, just download your simulator:,) I have a Twister pcm transmitter, usb cable, started simulator in cofigs seems that transmitter is working, but I cant take off the helicopter, or I dont how to start it:)
JS1
Re: Heli-x help
Post by JS1 »
You need to set Idle up (for arming the motor).
In the configuration menu set a key for idle-1 and idle-2.
When you loaded the helicopter, press this key and you should see the rotor start spinning.
Bahuras
Re: Heli-x help
Post by Bahuras »
thank you, already done, but its very difficult to control the helicopter or i had setuped the controls wrong, because its impossible to get it up and fly.
JS1
Re: Heli-x help
Post by JS1 »
Impossible or just difficult? What exactly is the problem? :?:
1) Can you start the rotor turning? If not, set idle up in the key configuration.
2) Could you get your controller to work in the calibration? If not, it is maybe a technical or USB problem.
3) Controller is recognized in calibration, Rotor is turning, but you can not increase throttle? If yes, calibration may be wrong. Also check direction of stick inputs is reversed etc.
4) Controller and keys are all working, but you have problems controlling the helicopter? If yes, also check calibration is correct and not reversed. If all is ok, maybe it is not a technical problem but a training issue? :roll: Maybe try another helicopter or a multicopter in stabilized ACC mode.
