I have the suggested HK-T6A Controller but of course it did not come with a USB connection. Does anyone know a way to get it to connect with Heli-x with a Mac?
Also...
I have a Dynam USB controller with USB connection. I am new to simulators and am here to use the Quadcopters. I do not know the sticks or directions that they are asking to set up the sticks correctly. Does anyone know of a link that shows visually how to set up the sticks and the meanings/directions that are required to set up the sticks correctly? Or if someone could let me know, I would really appreciate it. Thanks!
Setting up Controller
Re: Setting up Controller
viewtopic.php?f=24&t=1595Typeo wrote:I
Michael,
Thank you for the tips for setting up the Phantom Controller. I am still trying to get it connected correctly but am not having any luck. It is now saying that there is an Error and the channel cannot be detected. Sometimes it shows up and sometimes it does not. Im not too sure on what I am doing wrong.
Is Rudder the same as Yaw? Also I couldn't find where to switch it to Mode 2. I may not be in the correct mode. I apologize for being a pain in getting this set up. Thank you for all your help.
No, that was not what that post was showing. Read it. There is explained how the stick directions are called. That does not only apply for the Phantom, it's just how they are called. This could help too.Typeo wrote:Thank you for the tips for setting up the Phantom Controller.
yes, see here.Typeo wrote:Is Rudder the same as Yaw?
Mode 1 and 2 are just differently configured radios (like cars with steering on the left or on the right). They just have the stick orientations different. On most transmitters this can not be changed easily. In the Phantom post it is for Mode 2, but Mode 1 is almost the same simply with left and right hand controlls switched: pitch/yaw is on the right stick, roll/nick on the left stick (Mode 1). That's why you need to configure, to tell which channel on your radio is what control.Typeo wrote:Also I couldn't find where to switch it to Mode 2. I may not be in the correct mode.
alexseentr
Hey, while traveling through Berlin I had time to browse entertainment websites on my phone. I wanted to find a platform where betting and casino games work smoothly together. That’s when I opened https://play-jonny-casino.com/ and checked the site sections. There are slots, live games and a sportsbook area with many events. The platform also talks about promotions and deposit options in a simple way. It turned into something I open sometimes while following sports news.
