Helix 3.0 startet nicht
torsten_beltcp
Post by torsten_beltcp »
Hallo ,
nachdem die demo einwandfrei funktionierte, habe ich nun bei der freigeschalteten version einen schwarzen bildschirm:
hab ich mal als bild angehangen..
fehlermeldungen:
Couldn't find tag "AmbientSoundFile" in file "/home/torsten/Helisimulator/HELI-X30/resources/environments/Scene3D/Arctic_Zone_HD/Arctic_Zone_HD.xml"
java.net.MalformedURLException: unknown protocol: d
        at java.net.URL.<init>(URL.java:574)
        at java.net.URL.<init>(URL.java:464)
        at org.xith3d.loaders.models.conversion.XithAppearanceFactory.loadOrGetTexture(XithAppearanceFactory.java:746)
        at org.jagatoo.loaders.models.obj.OBJConverter.generateAppeances(OBJConverter.java:94)
        at org.jagatoo.loaders.models.obj.OBJConverter.convert(OBJConverter.java:233)
        at org.jagatoo.loaders.models.obj.OBJPrototypeLoader.load(OBJPrototypeLoader.java:375)
        at org.xith3d.loaders.models.ModelLoader.loadModel(ModelLoader.java:542)
        at org.xith3d.loaders.models.ModelLoader.loadModel(ModelLoader.java:561)
        at org.xith3d.loaders.models.ModelLoader.loadModel(ModelLoader.java:587)
        at org.xith3d.loaders.models.ModelLoader.loadModel(ModelLoader.java:742)
        at org.xith3d.loaders.models.ModelLoader.loadModel(ModelLoader.java:759)
        at a.a.a.p.b.a(Unknown Source)
        at a.a.a.h.c.a.<init>(Unknown Source)
        at a.a.a.d.d.a(Unknown Source)
        at a.a.a.e.f.a(Unknown Source)
        at a.a.a.l.n.<init>(Unknown Source)
        at a.a.a.l.e.run(Unknown Source)
        at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
        at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
        at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
        at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
        at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
        at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
        at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
da ich von java keine ahnung habe, kannst du mir sicherlich sagen was er will, bzw. wo das mit der url einzustellen ist.
Re: Helix 3.0 startet nicht
da scheint zwischendrin etwas passiert zu sein. Der Airport, der ausgewählt ist, ist nicht in der Demoversion möglich. Daraus schliesse ich, dass HELI-X schon freigeschaltet gelaufen ist, oder? Was ist dazwischen passiert?
Im Zwiefelsfall am files/Application/ApplicationSettings.xml löschen.
torsten_beltcp
nachdem löschen der ApplicationSettings.xml ist das problem geblieben , aber die fehlermeldung anders:
Exception in thread "AWT-EventQueue-0" javax.media.opengl.GLException: Unable to create OpenGL context
wieso er hier ein problem mit openGL hat ist mir nicht ganz klar, möglichweise weisst du mehr.
gruß
torsten
... dann bitte die Treiber der Grafikkarte aktualisieren ....
torsten_beltcp
gesagt getan:
Exception occurred during event dispatching:
Graka treiber : NVIDIA-Linux-x86_64-256.53.run
und nu ?
oder gibt es hier probleme im zusammenhang mit 64 bit ?
gruß
edit: ich habe also noch meine xorg.conf kontrolliert sowie das xorg logfile...
keine fehler soweit und die gl module werden geladen....
torsten
torsten_beltcp
gar keine idee ?
brauchst du noch infos ? oder möchtest du mal per ssh auf meine kiste schauen ?
by the way is ein debian sid 64 bit...
... es sieht so aus, als könnte Dein Grafikkartentreiber zu wenig openGL: create openGL context ...
Oder: Die 64-Bit-Sachen machen Probleme. Unter Linus ist statt
JOGL nicht immer optimal. Schau mal in files /Application/ApplicationSettings.xml
Dirt gibe es <OpenGLLayer>JOGL_AWT</OpenGLLayer>
Ersteze das mit <OpenGLLayer>LWJGL_AWT</OpenGLLayer>
torsten_beltcp
hi michael,
also.... lag nicht am heli-x und auch nicht an irgendwelchen einstellunge von heli-x.
eigentlich ganz simpel... die firma nvidia hat sich entschlossen, dass openGL erst wieder ab der treiberversion
NVIDIA-Linux-x86_64-260.19.12.run
mit vollständiger openGL unterstüzung daherkommt, so das es (wie wir ja nun wissen) hier und da zu problemen kommen kann.
ausserdem muss man, sollte man es auch funktionierend haben wollen, die run datei mit der option
./NVIDIA-Linux-x86_64-260.19.12.run --opengl-headers
aufrufen damit man dann das gewünschte ergebnis erziehlen kann.
in diesem sinne
cheers
