Help
mwahaha
Help
Post by mwahaha »
Has anyone managed to get this to work on ppc mac? There is no java6 for ppc only java 5. I can open the program and calibrate my controller but i cant load a heli, when i click ok nothing happens. I tried to load the only airfield i had access too and it loaded fine (even though i was already on it)
Re: Help
Hello mwahaha,
HELI-X should work on a PPC Mac with Java 5. Your problems might be due to a too poor graphics adapter. Is there anything wirtten in the console?
mwahaha
Re: Help
Post by mwahaha »
This is all i got in console
5/12/09 1:49:16 PM [0x0-0x10c10c].net.heli-x.heli-x[2157] Set new path for the resources: /Users/annemaclean/Library/Heli-X/resources/
5/12/09 1:49:16 PM [0x0-0x10c10c].net.heli-x.heli-x[2157] Set new path for the user files: /Users/annemaclean/Library/Heli-X/files/
5/12/09 1:49:18 PM [0x0-0x10c10c].net.heli-x.heli-x[2157] Using openGLLayer JOGL_AWT
5/12/09 1:49:19 PM [0x0-0x10c10c].net.heli-x.heli-x[2157] Found 30 display modes
5/12/09 1:49:20 PM [0x0-0x10c10c].net.heli-x.heli-x[2157] Controller found: Name: PPM(PPM)
5/12/09 1:49:20 PM [0x0-0x10c10c].net.heli-x.heli-x[2157] Using Stick PPM
5/12/09 1:49:20 PM [0x0-0x10c10c].net.heli-x.heli-x[2157] Digital component found:0
5/12/09 1:49:20 PM [0x0-0x10c10c].net.heli-x.heli-x[2157] Digital component found:1
5/12/09 1:49:20 PM [0x0-0x10c10c].net.heli-x.heli-x[2157] Digital component found:2
5/12/09 1:49:20 PM [0x0-0x10c10c].net.heli-x.heli-x[2157] Digital component found:3
5/12/09 1:49:20 PM [0x0-0x10c10c].net.heli-x.heli-x[2157] Digital component found:4
5/12/09 1:49:20 PM [0x0-0x10c10c].net.heli-x.heli-x[2157] Digital component found:5
5/12/09 1:49:20 PM [0x0-0x10c10c].net.heli-x.heli-x[2157] Digital component found:6
5/12/09 1:49:20 PM [0x0-0x10c10c].net.heli-x.heli-x[2157] Digital component found:7
5/12/09 1:49:20 PM [0x0-0x10c10c].net.heli-x.heli-x[2157] Digital component found:8
5/12/09 1:49:20 PM [0x0-0x10c10c].net.heli-x.heli-x[2157] Digital component found:9
5/12/09 1:49:20 PM [0x0-0x10c10c].net.heli-x.heli-x[2157] Digital component found:10
5/12/09 1:49:20 PM [0x0-0x10c10c].net.heli-x.heli-x[2157] Digital component found:11
5/12/09 1:49:20 PM [0x0-0x10c10c].net.heli-x.heli-x[2157] Analog component found:z
5/12/09 1:49:20 PM [0x0-0x10c10c].net.heli-x.heli-x[2157] Analog component found:rz
5/12/09 1:49:20 PM [0x0-0x10c10c].net.heli-x.heli-x[2157] Analog component found:x
5/12/09 1:49:20 PM [0x0-0x10c10c].net.heli-x.heli-x[2157] Analog component found:y
5/12/09 1:49:20 PM [0x0-0x10c10c].net.heli-x.heli-x[2157] Analog component found:rx
5/12/09 1:49:20 PM [0x0-0x10c10c].net.heli-x.heli-x[2157] Analog component found:ry
5/12/09 1:49:20 PM [0x0-0x10c10c].net.heli-x.heli-x[2157] Digital component found:pov
5/12/09 1:49:20 PM [0x0-0x10c10c].net.heli-x.heli-x[2157] Controller configuration file found: /Users/annemaclean/Library/Heli-X/files/controller/PPM.xml
5/12/09 1:49:20 PM [0x0-0x10c10c].net.heli-x.heli-x[2157] Controller configuration file /Users/annemaclean/Library/Heli-X/files/controller/PPM.xml read
Eddi E aus G
Re: Help
Post by Eddi E aus G »
Hi.
Did you choose lo-res airfields (Sky Box1024)? You will have to quit Heli-X and start it again to apply this change.
Which helis do you try and load? Start with using the HELIX types or the -LD ones ... others may have too many surfaces/details for an older computer/graphics board.
In Configuration / Performance, turn down or off Anti-Aliasing and turn on the "easy algorithms". You might also want to try and turn down resolution or color depth there, too. You will have to quit Heli-X and start it again to apply most of these changes.
I found sometimes when frame rates are low (even after re-booting which happens every few weeks or so ... I like my Mac therefore!), it helps re-starting Heli-X to improve frame rate.
I found that Java 6 brought a real boost to Heli-X ... so, even if you don't like Intel and the course Apple has taken, start thinking about a new Mac :D
Cheers
Eddi
mwahaha
Re: Help
Post by mwahaha »
Thanks for the help. I tried all that and still nothing happened. my frame rate is between 125 and 300 depending on how many apps i have going. i have a GeForce FX 5200 64mb graphics card and 1.5G ram, although i dont see why running this should be a problem when i can run x plane and battlefield ok. Another thing i noticed i try to load the 2 boxes with pylons scene and it gets stuck about 3/4 of the way loading.
Re: Help
Hi mwahaha,
is the console out you sent taken AFTER HELI-X did not respond anymore? I would expect an openGL error there ...
mwahaha
Re: Help
Post by mwahaha »
yes it is.
mwahaha
Re: Help
Post by mwahaha »
Ok here it is, for some reason this takes a while to show up in console
6/12/09 10:08:03 PM [0x0-0x1a71a7].net.heli-x.heli-x[3019] Controller configuration file /Users/annemaclean/Library/Heli-X/files/controller/PPM.xml read
6/12/09 10:09:36 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Set new path for the resources: /Users/annemaclean/Library/Heli-X/resources/
6/12/09 10:09:36 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Set new path for the user files: /Users/annemaclean/Library/Heli-X/files/
6/12/09 10:09:38 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Using openGLLayer JOGL_AWT
6/12/09 10:09:38 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Found 30 display modes
6/12/09 10:09:39 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Controller found: Name: PPM(PPM)
6/12/09 10:09:39 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Using Stick PPM
6/12/09 10:09:39 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Digital component found:0
6/12/09 10:09:39 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Digital component found:1
6/12/09 10:09:39 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Digital component found:2
6/12/09 10:09:39 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Digital component found:3
6/12/09 10:09:39 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Digital component found:4
6/12/09 10:09:39 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Digital component found:5
6/12/09 10:09:39 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Digital component found:6
6/12/09 10:09:39 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Digital component found:7
6/12/09 10:09:39 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Digital component found:8
6/12/09 10:09:39 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Digital component found:9
6/12/09 10:09:39 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Digital component found:10
6/12/09 10:09:39 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Digital component found:11
6/12/09 10:09:39 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Analog component found:z
6/12/09 10:09:39 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Analog component found:rz
6/12/09 10:09:39 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Analog component found:x
6/12/09 10:09:39 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Analog component found:y
6/12/09 10:09:39 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Analog component found:rx
6/12/09 10:09:39 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Analog component found:ry
6/12/09 10:09:39 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Digital component found:pov
6/12/09 10:09:39 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Controller configuration file found: /Users/annemaclean/Library/Heli-X/files/controller/PPM.xml
6/12/09 10:09:39 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Controller configuration file /Users/annemaclean/Library/Heli-X/files/controller/PPM.xml read
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Exception in thread "AWT-EventQueue-0" java.lang.AbstractMethodError: org.apache.xerces.dom.DeferredElementImpl.getTextContent()Ljava/lang/String;
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at a.a.a.m.l.a(Unknown Source)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at a.a.a.i.a.a(Unknown Source)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at a.a.a.j.e.D(Unknown Source)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at a.a.a.n.g.a(Unknown Source)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at a.a.a.e.a.i.actionPerformed(Unknown Source)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1882)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2202)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:420)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:258)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:236)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Component.processMouseEvent(Component.java:5602)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at javax.swing.JComponent.processMouseEvent(JComponent.java:3135)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Component.processEvent(Component.java:5367)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Container.processEvent(Container.java:2010)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Component.dispatchEventImpl(Component.java:4068)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Container.dispatchEventImpl(Container.java:2068)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Component.dispatchEvent(Component.java:3903)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4256)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.LightweightDispatcher.processMouseEvent(Container.java:3936)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.LightweightDispatcher.dispatchEvent(Container.java:3866)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Container.dispatchEventImpl(Container.java:2054)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Window.dispatchEventImpl(Window.java:1791)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.EventQueue.dispatchEvent(EventQueue.java:463)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:180)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Dialog$1.run(Dialog.java:535)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Dialog$2.run(Dialog.java:563)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.security.AccessController.doPrivileged(Native Method)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Dialog.show(Dialog.java:561)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Component.show(Component.java:1302)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Component.setVisible(Component.java:1255)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at a.a.a.e.a.i.c(Unknown Source)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at a.a.a.e.a.i.<init>(Unknown Source)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at a.a.a.n.m.actionPerformed(Unknown Source)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.MenuItem.processActionEvent(MenuItem.java:597)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.MenuItem.processEvent(MenuItem.java:556)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.MenuComponent.dispatchEventImpl(MenuComponent.java:298)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.MenuComponent.dispatchEvent(MenuComponent.java:286)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.EventQueue.dispatchEvent(EventQueue.java:466)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176)
6/12/09 10:10:54 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Exception in thread "AWT-EventQueue-0" java.lang.AbstractMethodError: org.apache.xerces.dom.DeferredElementImpl.getTextContent()Ljava/lang/String;
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at a.a.a.m.l.a(Unknown Source)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at a.a.a.i.a.a(Unknown Source)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at a.a.a.j.e.D(Unknown Source)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at a.a.a.n.g.a(Unknown Source)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at a.a.a.e.a.i.actionPerformed(Unknown Source)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1882)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2202)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:420)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:258)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:236)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Component.processMouseEvent(Component.java:5602)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at javax.swing.JComponent.processMouseEvent(JComponent.java:3135)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Component.processEvent(Component.java:5367)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Container.processEvent(Container.java:2010)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Component.dispatchEventImpl(Component.java:4068)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Container.dispatchEventImpl(Container.java:2068)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Component.dispatchEvent(Component.java:3903)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4256)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.LightweightDispatcher.processMouseEvent(Container.java:3936)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.LightweightDispatcher.dispatchEvent(Container.java:3866)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Container.dispatchEventImpl(Container.java:2054)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Window.dispatchEventImpl(Window.java:1791)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.EventQueue.dispatchEvent(EventQueue.java:463)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:180)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Dialog$1.run(Dialog.java:535)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Dialog$2.run(Dialog.java:563)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.security.AccessController.doPrivileged(Native Method)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Dialog.show(Dialog.java:561)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Component.show(Component.java:1302)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Component.setVisible(Component.java:1255)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at a.a.a.e.a.i.c(Unknown Source)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at a.a.a.e.a.i.<init>(Unknown Source)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at a.a.a.n.m.actionPerformed(Unknown Source)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.MenuItem.processActionEvent(MenuItem.java:597)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.MenuItem.processEvent(MenuItem.java:556)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.MenuComponent.dispatchEventImpl(MenuComponent.java:298)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.MenuComponent.dispatchEvent(MenuComponent.java:286)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.EventQueue.dispatchEvent(EventQueue.java:466)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176)
6/12/09 10:11:42 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] Exception in thread "AWT-EventQueue-0"
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] java.lang.AbstractMethodError: org.apache.xerces.dom.DeferredElementImpl.getTextContent()Ljava/lang/String;
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at a.a.a.m.l.a(Unknown Source)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at a.a.a.i.a.a(Unknown Source)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at a.a.a.j.e.D(Unknown Source)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at a.a.a.n.g.a(Unknown Source)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at a.a.a.e.a.i.actionPerformed(Unknown Source)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1882)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2202)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:420)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:258)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:236)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Component.processMouseEvent(Component.java:5602)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at javax.swing.JComponent.processMouseEvent(JComponent.java:3135)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Component.processEvent(Component.java:5367)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Container.processEvent(Container.java:2010)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Component.dispatchEventImpl(Component.java:4068)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Container.dispatchEventImpl(Container.java:2068)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Component.dispatchEvent(Component.java:3903)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4256)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.LightweightDispatcher.processMouseEvent(Container.java:3936)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.LightweightDispatcher.dispatchEvent(Container.java:3866)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Container.dispatchEventImpl(Container.java:2054)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Window.dispatchEventImpl(Window.java:1791)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.EventQueue.dispatchEvent(EventQueue.java:463)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:180)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Dialog$1.run(Dialog.java:535)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Dialog$2.run(Dialog.java:563)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.security.AccessController.doPrivileged(Native Method)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Dialog.show(Dialog.java:561)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Component.show(Component.java:1302)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.Component.setVisible(Component.java:1255)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at a.a.a.e.a.i.c(Unknown Source)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at a.a.a.e.a.i.<init>(Unknown Source)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at a.a.a.n.m.actionPerformed(Unknown Source)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.MenuItem.processActionEvent(MenuItem.java:597)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.MenuItem.processEvent(MenuItem.java:556)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.MenuComponent.dispatchEventImpl(MenuComponent.java:298)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.MenuComponent.dispatchEvent(MenuComponent.java:286)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.EventQueue.dispatchEvent(EventQueue.java:466)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176)
6/12/09 10:13:49 PM [0x0-0x1a81a8].net.heli-x.heli-x[3022] at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
mwahaha
Re: Help
Post by mwahaha »
Ok here it is, for some reason this takes a while to show up in console, so i didn't see it before. :oops:
Re: Help
Hallo mwahaha,
this seems to be a problem in your Java installation. A similar problem was reported e.g. here: http://lists.apple.com/archives/Java-de ... 00357.html
As a first thing you might want to make sure that your java installation is the most recent available. Then it might be that another program has installed a "wrong" Jar file in the ext-Directory of Java....
