Rev 2438
Rev 2438
a new revision is ready. You can download the demo version again to test, if everything works correctly also in the demo version.
And/or you can update. Please make sure to update the models so that you test the latest ones.
Last changes: User's manual available (at least in English), small bugs with the gui fixed.
Have fun
Mike656
Re: Rev 2438
Post by Mike656 »
Hi Michael
Do you have a link to the new user manual please?
Thanks
Re: Rev 2438
You get it inside of HELI-X V10 menu Options->user's manual
oneyogi
Re: Rev 2438
Post by oneyogi »
Hi
regarding
"Demo: Extra 330SC not starting @ Throttle (Dietersdorf & at least Plane-flying-field)"
I downloaded the linux version two days ago and saw you provided
-- only Almere , the Extra 330SC started fine
-- Registered and download Dietershof, Extra 330SC started fine now.
you also included
~/HELI-X10/Java/jre11/bin$ ./java -version
openjdk version "11.0.9.1" 2020-11-04
-- It seems as if that works smoother than
java -version
openjdk version "1.8.0_292"
OpenJDK Runtime Environment (build 1.8.0_292-8u292-b10-0ubuntu1~20.04-b10)
= the current standard in Ubuntu.
Regards, Yogi
michaelreese
Re: Rev 2438
Post by michaelreese »
I'm noticing two issues with fields in VR.
1. Sports_Hall has an erratic flashing texture on court surface.
2. Sporthalle has a model flying area that does not visually match the depth of the room, especially the higher you fly off floor surface.
swash23
Re: Rev 2438
Post by swash23 »
is it possible to load the last selected scene on by default on startup?
That would be nice
Regards
swash23
Re: Rev 2438
Post by swash23 »
sometimes during the Crash & Retry trainer the simulator gets stuck.
I have a video, but upload is not possible.
Regards
Re: Rev 2438
Thanks, I tried to find a problem without success. Can you send me your video with www.wetransfer.com via email?
Thanks.
swash23
Re: Rev 2438
Post by swash23 »
The video has been uploaded: https://file.io/mJYH39wzB1wn
Thanks
