According to some online sources, this combination should work with Heli-x, but for whatever reason, it doesn't recognize the input.
The model sits lifeless on the ground, and the controller stick view doesn't respond to real-work manipulations.
AccuRc sees the transmitter, and works fine.
Has anyone gotten this combination successfully working?
Using Spektrum D6Xe with a WS1000 USB Wireless receiver
Stupendousman
Re: Using Spektrum D6Xe with a WS1000 USB Wireless receiver
Did you perform the calibration process in HELI-X?
Stupendousman
I cannot. During calibration, there is no input received at all from the transmitter. Though it is "binded", none of the sticks have any effect at all.
That's why I'm wondering if anyone ever got the ws1000 to work with Heli-x...
I'm having the same issue. Any help out there?
Thanks, rick
Thanks, rick
please note that in the first step of the calibration the bars do not move.
Press "Sticks" and go through the process. The should move at the second step, first.
Thanks for help - progress, but not quite there.
The stick displays now move properly, but the throttle control isn't right.
I'm attempting to fly the Extra300 - all control surfaces move, but the prop doesn't spin nor does the model taxi or fly.
The transmitter display, however, shows the throttle moving up and down.
Any suggestions? THanks, rick
