Can't get roll to work on my controller...
zektiv
Post by zektiv »
So I've connected my FlySky TH9X to my computer successfully using a USB dongle to the buddybox connector. When I start up, my terminal literally says "Linux plugin claims to have found 11 controllers" and once in the application, I can run the "configuration" utility to get the sticks to calibrate or whatnot.
I can see feedback (though it 'flickers' quite a bit) and most of the channels seem to work, but I can't get the roll (right stick, left/right motion, Mode 2) to show any feedback in the configuration. Sure enough, I can't quite control the multicopter because it won't read the channel. Any ideas?
Thanks!
Re: Can't get roll to work on my controller...
When you have rev 1612 please download HELI-X again (Rev 1614). It is improved in the axis detection.
