Is there a way yet to program the Interlink Idle Up switch to use it's middle position?
The way it currently works on the back most and front most position register as a button. We need an additional button that is "set" whenever either of the other two states are not.
Windows Game Controllers show it as Button 4 and Button 5, so if we had a setting for !4 & !5 for example, we could make it work.
Thanks
Interlink Idle Up Switch - Way to use middle position?
Re: Interlink Idle Up Switch - Way to use middle position?
I do it so that idle up 1 is on 4 and idle up 2 is on 5 (or vice versa ?
Then I have Idle up 1 in the middle position and idles up 2 in the front position. The back position is then motor off.
Ah thanks Michael, I didn't realize you could have two buttons activated and one would take priority over the other.
So I setup
!Button4 = Idleup1
Button5= Idleup2
When the switch is in the Button 5 position, both conditions are met but the heli only goes into Idleup2 so it works fine.
Cheers
Tim
So I setup
!Button4 = Idleup1
Button5= Idleup2
Cheers
Tim
