Issues with Heli-X launching in OSx 10.8.2
Application will no longer launch. Shows up on dock then disappears. Console shows com.apple.launchd.peruser.501: ([0x0-0x4f04f].net.heli-x.heli-x[642]) Exited with code: 1. Using Java 7 update 13. Thanks.
Re: Issues with Heli-X launching in OSx 10.8.2
That package will only load with OSx 10.6. I'm running 10.8.2. Thanks.
Successfully installed the specified version of Java but, unfortunately, same result, same error.
Then you can try to remove Java 7.
michael
michael
ssalmenkivi
I have a similar problem with OSx 10.8.2 - I just downloaded Heli-X 4.2 but the dmg file doesn't start.
I have Java 1.6.0_41.
what exactly is going on? Could you unzip the file? Could you open the dmg file? Could you install the app?
michael
michael
So I finally figured out the issue. My antivirus software was blocking some of the files. Figuring that out was only half the problem! Then I had to figure out how to make it stop (which should have been much easier than it turned out to be). Anyway, I'm in good shape now. Thanks.
