Simple Airport Creation
cristianpark
Post by cristianpark »
Hi guys
I want to know how can I create a simple airport (maybe open field with no collitions). I'm seeing on resources/environments/SkyBox1024/BerlinCT and I see several images and a simple XML file, can I create one Airport that way? I only found this link in the main page (http://www.heli-x.info/documents/3D_Sce ... torial.pdf) Refering to 3D scenes creation (I'll translate it to english with Google Translate for more people to understand it) and I want to know if there's a tutorial for conventional airports since I want to create some local airports and share them
Thanks in advance
Re: Simple Airport Creation
Hi Cristian,
For a usual airport you just need 6 fotos from a panorama view. They are called skybox and I guess there are plenty of resources how to create them on the web. Once you have these 6 photos, just take a given xml file and modify it accordingly.
It is a good practice to give the photos the size 1024^2, 2048^2 od 4096^2.
