Heli-X on 10.10
avk2512
Re: Heli-X on 10.10
Post by avk2512 »
Hynek wrote:Hi,
Solution from Michael which worked for me:
Steps:
1. I have installed Java SDK from Oracle site
2. I have deleted the folder HELI-X5 (it is in the user's Library)
3. I did run the HeliX - it did start, but it did not launch the main screen.It did recreate the HELIX-5 folder.
3. In the HELIX-5 folder, I duplicated the file "liblwjgl.jnilib" and renamed the duplicate to "liblwjgl.dylib"
4. Started Helix, now it started properly, as "DEMO" version. Using an "Option" menu, I register myself.
5. After these steps, the Helix now works for me
Thanks Michael for the help.
Hynek
3. In the HELIX-5 folder, I duplicated the file "liblwjgl.jnilib" and renamed the duplicate to "liblwjgl.dylib" - this works fine and also for me! Thank you!
kerubyno
Re: Heli-X on 10.10
Post by kerubyno »
Steps:
avk2512
Re: Heli-X on 10.10
Post by avk2512 »
Michael, please fixthe install script for Heli-X OS X 10.10 :)
Re: Heli-X on 10.10
It is fixed. Just install the demo version again, it fixes the 10.10 issues.
heliquax
Re: Heli-X on 10.10
Post by heliquax »
This solution works for me :) Thanks for the hint!
franskoek wrote:Oke. After upgrading to Yosemite, Heli-X didn't work.
I installed Java RTE 8 from Oracle. After that I installed this; http://support.apple.com/kb/DL1572
And now it works fine! ;-))
HeliHajo
Re: Heli-X on 10.10
Post by HeliHajo »
Same here. :-(
Had to install the full Java 8 SDK to just have the app start up. (It starts with a flashing (i.e. on/off) splash screen - never had that before.)
But now, I experience extreme drops in framerate! When I start flying the heli I'm always <50 and mostly stay even below 20! That just doesn't work for me. Any ideas?
Hopefully,
HeliHajo
aehaas
Re: Heli-X on 10.10
Post by aehaas »
I tried all of the above but still cannot get it to start on the new MacPro.
aehaas
aehaas
Re: Heli-X on 10.10
Post by aehaas »
I started over again from scratch. This time it worked. It is important to do the Apple update when all else is done:
aehaas
aotearoa
Re: Heli-X on 10.10
Post by aotearoa »
I have installed Java 8 and deleted the folder Heli-X in the library.The downloaded Demoversion 5.0 cannot be installed.
Meanwhile I have tried all recommendations made in this forum to succeed.But in vain.My problem is,that i cannot create
the heli-x folder in the library.Because the installation of the program fails.
happydays
Re: Heli-X on 10.10
Post by happydays »
Same for me, nothing works. Just keeps on telling me to install Java Runtime Environment.
Also, the apple support DL1572 doesn't open for me. :o :o :o :o
