Heli-X on 10.10
joepaisley
Heli-X on 10.10
Post by joepaisley »
I just tried to run on 10.10 and I get the splash screen but the main display does not appear. Any logs I can send to help with testing?
Thanks.
Re: Heli-X on 10.10
I assume you run the program on a Mac. I don't know anything about Macs, but I assume that the "status window" also appears on a Mac (It appears under Windows and Linux). The output is not automatically written to a file, but you can use copy/paste to generate such a log and post it here.
Hope it helps
rbakharev
Re: Heli-X on 10.10
Post by rbakharev »
Hello, i have problem too. Not start main window. OSx Yosemite. :( please fix it
rbakharev
Re: Heli-X on 10.10
Post by rbakharev »
when i opened app with terminal:
Last login: Thu Sep 18 21:58:33 on console
romans-mbp:~ romanbakharev$ /Applications/HELI-X5.app/Contents/MacOS/launch.command ; exit;
Set new path for the resources: /Users/romanbakharev/Library/HELI-X5/resources/
Set new path for the user files: /Users/romanbakharev/Library/HELI-X5/files/
No Joystick found
Exception in thread "LWJGL Renderer Thread" java.lang.UnsatisfiedLinkError: Can't load library: /Users/romanbakharev/Library/HELI-X5/liblwjgl.dylib
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1817)
at java.lang.Runtime.load0(Runtime.java:809)
at java.lang.System.load(System.java:1083)
at org.lwjgl.Sys$1.run(Sys.java:70)
at org.lwjgl.Sys.doLoadLibrary(Sys.java:66)
at org.lwjgl.Sys.loadLibrary(Sys.java:95)
at org.lwjgl.Sys.<clinit>(Sys.java:112)
at com.jme3.system.lwjgl.LwjglAbstractDisplay.run(LwjglAbstractDisplay.java:206)
rbakharev
Re: Heli-X on 10.10
Post by rbakharev »
Somebody help please
Hynek
Re: Heli-X on 10.10
Post by Hynek »
I have installed new operating system Yosemite (10.10) and now I cannot use Helix.
When I clicked on Helix to start it, I got a message from the system that to use this application I have to install Java 8 from Oracle site.
I did install Java 8 run time system from the Oracle site, but nothing changed, I am getting the same message.
Any advise?
Thanks
Hynek
Solution from Michael which worked for me:
Steps:
1. I have installed Java SDK from Oracle site
2. I have deleted the folder HELI-X5 (it is in the user's Library)
3. I did run the HeliX - it did start, but it did not launch the main screen.It did recreate the HELIX-5 folder.
3. In the HELIX-5 folder, I duplicated the file "liblwjgl.jnilib" and renamed the duplicate to "liblwjgl.dylib"
4. Started Helix, now it started properly, as "DEMO" version. Using an "Option" menu, I register myself.
5. After these steps, the Helix now works for me
Thanks Michael for the help.
Hynek
heliquax
Re: Heli-X on 10.10
Post by heliquax »
Dear all,
I have the same problem :(
Best regards,
Hynek wrote:Hi,
Any advise?
Thanks
Hynek
bwing
Re: Heli-X on 10.10
Post by bwing »
Little bit different for me.
I installed the Java from the Oracle Side after the request. Now Heli-X starts, opens the statistics window but no main window.
Best Regards
Bernhard
Re: Heli-X on 10.10
Hello
there seem to be some issues with Moc AS X 10.10. For the Moment, please try the following:
1. Delete the Folder HELI-X5 in your peroinal libraray Folder.
2. Download and install JavaJRE or SDK from Oracle.
3. Try to run the HELI-X app.
4. If it still Dows not work: Copy liblwjgl.jnilib in your HELI-X5 folder of the peronal libarary folder to liblwjgl.dylib in the same folder.
Does it work?
bwing
Re: Heli-X on 10.10
Post by bwing »
Hi Michael,
when you said "Softlink" in your mail from last night, I made an alias which didn't help.
Now I made a copy and this works!!
Thanks for your support.
Bernhard
