Guten Tag Michael,
nach der Installation und dem ersten Aufruf kommt diese Fehlermeldung:
C:\ProgramData\HELI-X10>"C:\Program Files\HELI-X10\Java\jre11\bin\java.exe" --add-opens=java.base/jdk.internal.ref=ALL-UNNAMED -Djdk.tls.client.protocols=TLSv1.2 -Djava.library.path="C:\ProgramData\HELI-X10" -DheliX.path.resources="C:\ProgramData\HELI-X10\resources" -DheliX.path.files="C:\ProgramData\HELI-X10\files" -Xms512m -classpath ./libs/HeliX/HeliX10.jar;./libs/HeliX/HeliX_VR.jar;./libs/HeliX/Translation.jar;./libs/HeliX/Media.jar;./libs/jme/jme3-core.jar;./libs/jme/jme3-plugins.jar;./libs/jme/jme3-terrain.jar;./libs/jme/jme3-desktop.jar;./libs/jme/jme3-jogg.jar;./libs/jme/jme3-lwjgl3.jar;./libs/jme/jme3-effects.jar;./libs/jme/lwjgl.jar;./libs/jme/lwjgl-glfw.jar;./libs/jme/lwjgl-opengl.jar;./libs/jme/lwjgl-jemalloc.jar;./libs/jme/lwjgl-openal.jar;./libs/jme/lwjgl-openvr.jar;./libs/jme/nifty.jar;./libs/jme/jme3-niftygui.jar;./libs/jme/xpp3.jar;./libs/jme/jutils.jar;./libs/jdom/jdom.jar;./libs/javagamenetworking/jgn.jar;./libs/math/openmali.jar;./libs/jme/j-ogg-all.jar;./libs/jme/gson.jar;./libs/jme/styles.zip;./libs/jme/nifty-default-controls.jar;./libs/jSerial/jSerialComm-2.4.0.jar HELIX
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by com.jme3.util.ReflectionAllocator (file:/C:/ProgramData/HELI-X10/libs/jme/jme3-core.jar) to method sun.nio.ch.DirectBuffer.cleaner()
WARNING: Please consider reporting this to the maintainers of com.jme3.util.ReflectionAllocator
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
java.lang.NullPointerException
at net.HeliX.g.s.onJoyAxisEvent(Unknown Source)
at com.jme3.input.InputManager.processQueue(InputManager.java:843)
at com.jme3.input.InputManager.update(InputManager.java:917)
at com.jme3.app.LegacyApplication.update(LegacyApplication.java:724)
at net.HeliX.v.i.update(Unknown Source)
at net.HeliX.v.o.update(Unknown Source)
at com.jme3.system.lwjgl.LwjglWindow.runLoop(LwjglWindow.java:530)
at com.jme3.system.lwjgl.LwjglWindow.run(LwjglWindow.java:632)
at com.jme3.system.lwjgl.LwjglWindow.create(LwjglWindow.java:466)
at com.jme3.app.LegacyApplication.start(LegacyApplication.java:463)
at com.jme3.app.LegacyApplication.start(LegacyApplication.java:424)
at net.HeliX.v.i.start(Unknown Source)
at net.HeliX.c.a.<init>(Unknown Source)
at net.HeliX.c.a.f(Unknown Source)
at HELIX.main(Unknown Source)
Hier die Hardware:
Betriebsystemname Microsoft Windows 10 Pro
Version 10.0.19044 Build 19044
Zusätzliche Betriebsystembeschreibung Nicht verfügbar
Betriebsystemhersteller Microsoft Corporation
Systemhersteller Hewlett-Packard
Systemmodell HP Z620 Workstation
Systemtyp x64-basierter PC
System-SKU C8M57UP#ABU
Prozessor Intel(R) Xeon(R) CPU E5-1650 v2 @ 3.50GHz, 3501 MHz, 6 Kern(e), 12 logische(r) Prozessor(en)
BIOS-Version/-Datum Hewlett-Packard J61 v03.96, 29.10.2019
SMBIOS-Version 2.7
Version des eingebetteten Controllers 255.255
BIOS-Modus Vorgängerversion
BaseBoard-Hersteller Hewlett-Packard
Hardwareabstraktionsebene Version = "10.0.19041.1151"
Zeitzone Mitteleuropäische Zeit
Installierter physischer Speicher (RAM) 32,0 GB
Gesamter physischer Speicher 31,9 GB
Verfügbarer physischer Speicher 24,3 GB
Gesamter virtueller Speicher 32,7 GB
Verfügbarer virtueller Speicher 22,3 GB
Größe der Auslagerungsdatei 800 MB
Auslagerungsdatei C:\pagefile.sys
Kernel-DMA-Schutz Aus
Virtualisierungsbasierte Sicherheit Nicht aktiviert
V10 Java Exception
Re: V10 Java Exception
Oupps, da ist ein Problem mit dem Controller.
Hast Du normal installiert, oder Daten von V9 übernommen?
Hast Du einen Controller angeschlossen? Welchen?
rolandrasch
Besten Dank für die schnelle Hilfe und den Hinweis, das Problem ist gelöst.
Ich hatte keinen Import von Altdaten aus V9 durchgeführt.
Ich benutze einen RX2SIM. Der Rechner hat ein VR-Setup mit HTC-Vive und Fanatec-Lenkrad für iracing, einer Rennsimulation. Nach deinem Hinweis habe ich gesehen, dass das Fanatec-System ebenfalls als Gamecontroller aufgeführt wird. Nach dem manuellen Ausschalten des Fanatec-Lenkrads startet die V10. Der V9 macht das übrigens nichts aus, sie startet immer, egal ob das Lenkrad aktiv ist oder nicht.
Nochmals vielen Dank, wünsche Dir einen schönen 3. Advent.
