VR Hardware
Re: VR Hardware
Any words on the benefit of using VR over a monitor?
Franksheliinfo
Re: VR Hardware
Samsung Odyssey+
Nvidia RTX 2070
AMD Ryzen 7 1700x
Nvidia RTX 2070
AMD Ryzen 7 1700x
Re: VR Hardware
AMD Radeon 5700XT
Valve Index
R9 5950X
works perfectly!! Great VR-Support! This Simulator really impress me!
Valve Index
R9 5950X
Re: VR Hardware
HP Reverb G2
Nvidia GEForce GTX1070 8GB
Intel i7, 16GB RAM
(New to VR) having trouble with:
- Heli-X sound cutting out after a while
- using the mouse inside the headset: mouse freezes when wearing the headset, can be used in 3D preview window when taking it off.
Intel i7, 16GB RAM
Re: VR Hardware
@lama12
The mouse appears to be restricted to the area shown on the laptop Heli-x screen, and may only show a smaller area than that available when wearing your glasses. Try ctrl-alt-F11 to change the view on the laptop.
Re: VR Hardware
Oculus Rift S
Nvidia GeForce RTX 2060
Re: VR Hardware
Thanks Mike, however I discovered that it is the proximity sensor in the G2 that detects wearing it that disables the mouse movement. This is exactly opposite of how it should work IMHO. I think that only happens when launching HeliX for a second time or more after a reboot. Bit I need to test it some more. Still new to the G2 and VR. Also the cable needs replacement due to USB issues so this may be due to the cable too ….
Re: VR Hardware
Hi lama12lama12 wrote: ↑06 Nov 2021 21:34Thanks Mike, however I discovered that it is the proximity sensor in the G2 that detects wearing it that disables the mouse movement. This is exactly opposite of how it should work IMHO. I think that only happens when launching HeliX for a second time or more after a reboot. Bit I need to test it some more. Still new to the G2 and VR. Also the cable needs replacement due to USB issues so this may be due to the cable too ….
On the mixed reality screen, pressing win-Y allows the mouse to work in the glasses
Re: VR Hardware
Thanks Mike, I also disabled the proximity sensor now all is predictable again.Mike656 wrote: ↑07 Nov 2021 08:45Hi lama12lama12 wrote: ↑06 Nov 2021 21:34Thanks Mike, however I discovered that it is the proximity sensor in the G2 that detects wearing it that disables the mouse movement. This is exactly opposite of how it should work IMHO. I think that only happens when launching HeliX for a second time or more after a reboot. Bit I need to test it some more. Still new to the G2 and VR. Also the cable needs replacement due to USB issues so this may be due to the cable too ….
