I have a Corsair K70 RGB MK.2 keyboard and HELI-X would not recognize my RealFlight Interlink controller. After some searching, I tried disabling one of the HID-compliant mouse devices in Device Manager in Windows 10. It's trial-and-error if you disable the wrong one, the keyboard or mouse won't work. Just re-enable and try disabling the next device. I knew it was fixed when I was able to use my keyboard and mouse, as well as start HELI-X and it recognized my controller. Major Windows 10 updates also reset the devices and I have to redo this process.
Hope this helps someone else!
Corsair Keyboard and No Joystick found [SOLVED]
- fix corsair heli-x controller not found (2).png (6.1 KiB) Viewed 13333 times
