Hey,
after a new beta release version of El Capitan (OS X 11.2) the controller is not found during the initialisation process in heli-x, although a joystick tester shows stick movements.
Any idea to get the controller visible to heli-c v6 again?
Rolf
El Capitan: no joystick found
RolfHeller
Glück auf!
Rolf
Rolf
Re: El Capitan: no joystick found
it might be a problem of the USB devices. Also when unusaul, make a reboot of the Mac. Otherwise there might be driver missing.
RolfHeller
Hey,
Rebooting does'nt help.
On command-level it says:
Last login: Tue Nov 10 11:14:18 on ttys000
Ursula-Heller-Heisings-iMac:~ RolfHeller$ /Applications/HELI-X6.app/Contents/runHELI-X.command ; exit;
Set new path for the resources: /Applications/HELI-X6.app/Contents/resources/
Set new path for the user files: /Applications/HELI-X6.app/Contents/files/
Directory /Applications/HELI-X6.app/Contents/resources/Translation/ created
Directory /Applications/HELI-X6.app/Contents/files/Application/ created
Directory /Applications/HELI-X6.app/Contents/files/controller/ created
Directory /Applications/HELI-X6.app/Contents/files/screenshots/ created
Directory /Applications/HELI-X6.app/Contents/files/Server/ created
Directory /Applications/HELI-X6.app/Contents/files/lists/ created
Couldn't find tag "WindowSettings" in file "/Applications/HELI-X6.app/Contents/files/Application/ApplicationSettings.xml"
Couldn't find tag "InfoWindow" in file "/Applications/HELI-X6.app/Contents/files/Application/ApplicationSettings.xml"
Couldn't find tag "ChatWindow" in file "/Applications/HELI-X6.app/Contents/files/Application/ApplicationSettings.xml"
No Joystick found
2015-11-10 11:19:18.528 java[1231:286762] 11:19:18.527 WARNING: 140: This application, or a library it uses, is using the deprecated Carbon Component Manager for hosting Audio Units. Support for this will be removed in a future release. Also, this makes the host incompatible with version 3 audio units. Please transition to the API's in AudioComponent.h.
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
Deleting expired sessions...none found.
[Prozess beendet]
Does it help?
No Joystick found
logout
Saving session...
...completed.
[Prozess beendet]
Does it help?
Glück auf!
Rolf
Rolf
martinsalem
i also have this problem
HI
I did not try the newst OSX, yet. Is HELI-X running in principle? Playing videos, etc.?
This message "No Joystick found" shows that there is no joystick found by HELI-X. I am not sure if your hardware requires a specific driver.
Waht hardware do you have exactly as a joystick?
RolfHeller
Hey,
thanks for your support.
The problem vanishes into thin air as soon as I updated today into the "OS X El Capitan Update Public Beta 3".
Hopefully the next mayor release will not show this "unwanted feature".
The unwanted status before was: It shows the Heli-x airport and heli, but no noise and no movement of the rotor.
When trying to calibrate inside hell-x it says: "No joystick found".
The name of my controller, shown in the OS X configuration under "USB", is: SAILI Simulator --- XTR5.5+G2+FMS Controller
See you.
See you.
Glück auf!
Rolf
Rolf
