there is an update of the Garage Airport available. If you have problems with the performance, give it a try.
Update of the Garage Airport
toomuchcookies
Re: Update of the Garage Airport
I am running version 2015-3-7 ( ) of the Garage airport, but heli-x keeps telling me,
"Underground_Garage: Object is not available
Please update from the HELI-X server."
I then can update the airport, but the error message keeps popping up.
Hello
I cannot reproduce this. Do others have this probem?
Here absolutely no problem, cannot confirmMichael wrote:Hello
I had no problem updating from the server. It installed with no issue
toomuchcookies
Is there any log file i could look into? Otherwise i guess the next step would be to download the files again?
By the way i am running heli-x under linux.
toomuchcookies
ok, i just found the problem:
In the file Underground_Garage.xml the file names with _Box_ in them do not correspond to the file names in the path. At least not if the system is looking for case sensitive file names.
So, i changed the path-parameters where i could find a "Box" into "box" and now it seems to work.
For example:
into
I guess, you would want to update that file, otherwise linux and mac users will have a problem with it.
For example:
<Object FrictionFactor="0.5" MakeCrashObject="true">
<Path> AWall_Box_mx.obj </Path>
<Translation> 12,0,-4 </Translation>
<Rotation> 0 </Rotation>
<ShadowCaster> false </ShadowCaster>
<ShadowReceiver>true </ShadowReceiver>
</Object>
</Object>
thank you!toomuchcookies wrote: .., i changed the path-parameters where i could find a "Box" into "box" ...
That was it!
Yes, thanks. The download is corrected.
