habe ein Problem, wenn ich HD-Fluggelände lade. Der Dialog mit dem Ladebalken wird dann nicht richtig geschlossen und auf der Konsole sehe ich mehrfach den folgenden Fehler:
java.lang.OutOfMemoryError: Direct buffer memory
at java.nio.Bits.reserveMemory(Bits.java:656)
at java.nio.DirectByteBuffer.<init>(DirectByteBuffer.java:113)
at java.nio.ByteBuffer.allocateDirect(ByteBuffer.java:305)
at org.jagatoo.util.nio.BufferUtils.createByteBuffer(BufferUtils.java:58)
at org.xith3d.scenegraph.TextureImage2D.setImageData(TextureImage2D.java:512)
at org.xith3d.scenegraph.TextureImage2D.setImageData(TextureImage2D.java:613)
at org.xith3d.loaders.texture.Xith3DTextureFactory2D.createTextureImageImpl(Xith3DTextureFactory2D.java:69)
at org.xith3d.loaders.texture.Xith3DTextureFactory2D.createTextureImageImpl(Xith3DTextureFactory2D.java:1)
at org.jagatoo.loaders.textures.TextureFactory.createTextureImage(TextureFactory.java:100)
at org.jagatoo.loaders.textures.TextureFactory.createTextureImage(TextureFactory.java:119)
at org.jagatoo.loaders.textures.TextureFactory.createTextureImage(TextureFactory.java:137)
at org.jagatoo.loaders.textures.TextureFactory.createTextureImage(TextureFactory.java:196)
at org.jagatoo.loaders.textures.formats.TextureImageFormatLoaderImageIOImageInputStream.createTextureImage(TextureImageFormatLoaderImageIOImageInputStream.java:126)
at org.jagatoo.loaders.textures.formats.TextureImageFormatLoaderImageIOImageInputStream.loadTextureImage(TextureImageFormatLoaderImageIOImageInputStream.java:252)
at org.jagatoo.loaders.textures.AbstractTextureLoader.loadFromFallbackLoader(AbstractTextureLoader.java:390)
at org.jagatoo.loaders.textures.AbstractTextureLoader.loadTextureFromStream(AbstractTextureLoader.java:542)
at org.jagatoo.loaders.textures.AbstractTextureLoader.loadOrGetTexture(AbstractTextureLoader.java:723)
at org.xith3d.loaders.texture.TextureLoader.getTexture(TextureLoader.java:258)
at org.xith3d.loaders.texture.TextureLoader.getTexture(TextureLoader.java:281)
at org.xith3d.loaders.texture.TextureLoader.getTexture(TextureLoader.java:297)
at org.xith3d.loaders.texture.TextureLoader.getTexture(TextureLoader.java:389)
at a.a.a.f.d.a(Unknown Source)
at a.a.a.g.f.a(Unknown Source)
at a.a.a.m.o.a(Unknown Source)
at a.a.a.c.a.o.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2012)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2335)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:404)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:253)
at java.awt.Component.processMouseEvent(Component.java:6268)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
at java.awt.Component.processEvent(Component.java:6033)
at java.awt.Container.processEvent(Container.java:2045)
at java.awt.Component.dispatchEventImpl(Component.java:4629)
at java.awt.Container.dispatchEventImpl(Container.java:2103)
at java.awt.Component.dispatchEvent(Component.java:4455)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4633)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4297)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4227)
at java.awt.Container.dispatchEventImpl(Container.java:2089)
at java.awt.Window.dispatchEventImpl(Window.java:2517)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:649)
at java.awt.EventQueue.access$000(EventQueue.java:96)
at java.awt.EventQueue$1.run(EventQueue.java:608)
at java.awt.EventQueue$1.run(EventQueue.java:606)
at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:105)
at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:116)
at java.awt.EventQueue$2.run(EventQueue.java:622)
at java.awt.EventQueue$2.run(EventQueue.java:620)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:619)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:275)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:200)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:194)
at java.awt.Dialog$1.run(Dialog.java:1072)
at java.awt.Dialog$3.run(Dialog.java:1126)
at java.awt.Dialog.show(Dialog.java:1124)
at java.awt.Component.show(Component.java:1551)
at java.awt.Component.setVisible(Component.java:1503)
at java.awt.Window.setVisible(Window.java:881)
at java.awt.Dialog.setVisible(Dialog.java:1011)
at a.a.a.m.h.b(Unknown Source)
at a.a.a.m.s.actionPerformed(Unknown Source)
at java.awt.MenuItem.processActionEvent(MenuItem.java:644)
at java.awt.MenuItem.processEvent(MenuItem.java:603)
at java.awt.MenuComponent.dispatchEventImpl(MenuComponent.java:332)
at java.awt.MenuComponent.dispatchEvent(MenuComponent.java:320)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:652)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:185)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:177)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:138)Das Problem kann ich umgehen, wenn ich im Startscript die Zeile:
$JAVAPATH/java -Xmx384m -Djava.library.path="$LIBS" -classpath "$CP" HELIX > files/log.txtCode: Select all
$JAVAPATH/java -Xmx1024m -Djava.library.path="$LIBS" -classpath "$CP" HELIX > files/log.txtIch hoffe das Problem lässt sich beheben. Auf jeden Fall schon mal vielen Dank für die Bemühungen und generell für den tollen Simulator
