Heli-x linux opengl crash
grusin
Post by grusin »
Hi guys,
I'm trying to run heli-x on my laptop (on pc it works great). Laptop has intel 940 card (running intel 810 driver). When starting I get following exception:
grusin@it-grusin:~/Desktop/HELI-X$ ./runHELI-X.sh
Application started
3D Environment created
Found 2 display modes
Using display mode 1024x768x?x60
Exception during event dispatch:
java.lang.Error: java.lang.reflect.InvocationTargetException
at org.xith3d.render.Canvas3DFactory.create(Canvas3DFactory.java:127)
at org.xith3d.render.Canvas3DFactory.create(Canvas3DFactory.java:149)
at org.xith3d.render.Canvas3DFactory.create(Canvas3DFactory.java:307)
at org.xith3d.render.Canvas3DPanel.<init>(Canvas3DPanel.java:286)
at org.xith3d.render.Canvas3DPanel.<init>(Canvas3DPanel.java:372)
at ch.ntb.HeliX.simulation.Simulation.initCanvas(Simulation.java:188)
at ch.ntb.HeliX.simulation.Simulation.<init>(Simulation.java:123)
at ch.ntb.HeliX.application.Application.<init>(Application.java:146)
at ch.ntb.HeliX.application.Application$1.run(Application.java:757)
at java.awt.event.InvocationEvent.dispatch(libgcj.so.81)
at java.awt.EventQueue.dispatchEvent(libgcj.so.81)
at java.awt.EventDispatchThread.run(libgcj.so.81)
Caused by: java.lang.reflect.InvocationTargetException
at java.lang.reflect.Constructor.newInstance(libgcj.so.81)
at org.xith3d.render.Canvas3DFactory.create(Canvas3DFactory.java:123)
...11 more
Caused by: java.lang.IllegalArgumentException: GLDrawableFactory.chooseGraphicsConfiguration() was not used when creating this Component
at com.sun.opengl.impl.x11.X11GLDrawableFactory.getGLDrawable(X11GLDrawableFactory.java:238)
at javax.media.opengl.GLCanvas.<init>(GLCanvas.java:142)
at org.xith3d.render.jsr231.CanvasPeerImplAWT.<init>(CanvasPeerImplAWT.java:118)
...12 more
Any ideas how to get rid of it? ;-)
Regards,
Grzegorz
Re: Heli-x linux opengl crash
Hi Grzegorz,
welcome at this forum. Some questions:
Does your PC-version run on Linux? Do you have a 32 or 64 bit linux on your Notebook? Try to get the newest drivers for your graphics adapter. Make sure, you use the right java version. Do you use the newest download? Two weeks ago I made an update with some libs.
