Issue with no rotation in training
Posted: 19 Sep 2022 16:16
by Sid Dennis
I am using full version.
i looked for advice on learning with a sim.
read its good to learn to hover with a slow piro, 1 rotation per minute.
if i use the rudder trim in config the heli starts tail in,turns to side on then stops.
i found in the training section a option on rotation,chose i per minute but again it stops side on.
i chose heli-x the control rudder and it also stops side on.
i have looked to see if there is a camera view or angle that might need changing but can not see one thats relevent.
any ideas?
Re: Issue with no rotation in training
Posted: 01 Oct 2022 10:10
by azaz44
Why don't you just trim in your radio?
Posted: 02 Oct 2022 09:37
Hi
I just tried this setting with the Specter V2 and it rotates very slowly, as expected. I stopped after 360 degrees
It might be, that by your input on aileron and elevator, you influence the rotations ...
Posted: 09 Jun 2025 12:36
by AxelM
I have the same problem, if you activate rudder in manual mode, it doesn't manage to make the complete turn in 1min.
Posted: 10 Jun 2025 05:15
by admin
Are you using V11? Please also try the other speeds.
