"No controller found" when using FrSky QX7S
superhero
Post by superhero »
Hi
I have my Taranis QX7S hooked up to my computer via USB and Windows sees the controller just fine.
However, I go to load Heli-X, and it just says no controller found.
I have read other people online have had no problems doing this, but I cannot get it to work. Any help would be appreciated.
Windows 7 x64
Heli-X v7 demo (not going to buy this unless I know my controller will work)
OpenTX 2.2
Re: "No controller found" when using FrSky QX7S
does Wondows recognize the controller as joystick? Can you perform a calibration in the windows system settings and you see the movements of the sticks there? (Everything without HELI-X).
superhero
Post by superhero »
Yes, Windows sees it just fine. I can run ClearView no problem. In fact I can load up regular games and use it if I choose.
No go with heli-x :(
a) just to be sure: you are using version 7 of HELI-X?
b) Did you install the version so that you have write access: Ideally in c:\HEli-X7 ? Do not install it in the programs folder.
c) Is there anything interesting visible in the terminal window (HELI-X menu, simulation->terminal ?
superhero
Post by superhero »
Yes, fresh download of Heli-X v7. Version #7.0.1735
Installed to c:\HELI-X7 (default directory from the installer)
Nothing interesting in the terminal. Last line is "no joystick found"
Thank you for your help!
Ok, then I see two possibilities:
a) Sometimes Windows assigns an USB to a single process. Thus a reboot might help.
b) Use configuration->global options and try different input systems. You have to restart HELI-X afterwards.
I would try a) first.
superhero
Post by superhero »
I tried rebooting. Didn't help.
There are three different .jar files under global--input. I'll try those.
superhero
Post by superhero »
Changing the inputs between the various java files didn't do anything. :(
superhero
Post by superhero »
Could this perhaps be an issue with java itself?
Well,
clearview uses also java, but maybe it is a problem of the java version.
If you are a bit familiar with computers:
In C:\HELI-X7 there is the file runHELI-X.bat which is the start script of HELI-X.
You could edit it (e.g. with notepad) and change the line
Java\jre8\bin\java.exe -Djava.library.path=%libPath% -Xms512m -classpath %jars% HELIX
into
java -Djava.library.path=%libPath% -Xms512m -classpath %jars% HELIX
Then HELI-X uses the already installed java version of your system. ;aybe this helps.
