Inacceptable Stick Movement Delay
Poldi
Post by Poldi »
I am trying to run Heli-X 6 on Win 8.1, which works in general fine.
However: My stick input suffers a delay of several tenth of a second. When putting the sticks display on the screen and twitching in one direction, I can watch the twitch after my TX stick is already in rest.
This will completely spoil doing fast maneuvers. I would like to purchase the full Version, however, without the issue being resolved it is not an option.
How do I get rid of this delay? USB link issue? Set-up issue?
Regards,
Poldi
Re: Inacceptable Stick Movement Delay
How many FPS do you have?
Poldi
Post by Poldi »
Not sure which you mean:
The openGL setting is unlimited FPS.
My PPM Settings are
Center PW 1100
Delta PW 400
Notch PW 400
Frame Size 22500
The TX should be capable of 11ms 2048.
Regards,
Poldi
@Poldi: the actual fps value is displayed in the window top line next to airport and model name
Poldi
Post by Poldi »
Thanks, Thomas, for helping out.
The FPS displayed is a seemingly disappointing 12 to 14.
14 FPS is too slow. Try to load an airport of type SkyBox1024.
Poldi
Post by Poldi »
Hello Michael,
I have the Heli Flying Field and Dietersdorf available, both of them I choose 'low' resolution. On the Heli Flying Field I only get 11 FPS.
Regards,
Poldi
And how many FPS do you get in Dietersdorf with low resolution?
Poldi
Post by Poldi »
The 12 to 14 FPS stated earlier were Dietersdorf, low resolution.
Regards,
Poldi
Then please check your anti alias settings and reduce them if possible.
