Controller configuration error
Posted: 02 Jul 2012 14:38
I was just trying to use v3.0 as I had done many times successfully. When I took off, he heli (Mini Titan) was turning left slowly and pitching nose up slowly so I thought it would be good to reconfigure the settings. I went to the Controller screen and followed the instructions. When I pressed "OK" to finish, I got a blank box with the title "Error" and an OK button. I pressed the OK button which removed the error box, but it came back if I pressed OK on the config finish box.
I closed the box and re-ran Heli -x. When I tried to take off, the heli rolled right and pitched forward. I went into the Controller screens again, and found the collective and the cyclic had somehow become linked to give the result described. I tried the process several times, but got the same result.
Any ideas?
I am just downloading v4.0 as I write.
Any ideas?
