OSX 10.6.5
rraith
OSX 10.6.5
Post by rraith »
Mit OSX 10.6.5 hängt sich Heli-X auf:
12/11/10 4:16:50 PM [0x0-0x25025].net.heli-x.heli-x[203] Set new path for the resources: /Users/adm/Library/Heli-X/resources/
12/11/10 4:16:50 PM [0x0-0x25025].net.heli-x.heli-x[203] Set new path for the user files: /Users/adm/Library/Heli-X/files/
12/11/10 4:16:50 PM [0x0-0x25025].net.heli-x.heli-x[203] Couldn't find tag "WindowSettings" in file "/Users/adm/Library/Heli-X/files/Application/ApplicationSettings.xml"
12/11/10 4:16:50 PM [0x0-0x25025].net.heli-x.heli-x[203] Couldn't find tag "InfoWindow" in file "/Users/adm/Library/Heli-X/files/Application/ApplicationSettings.xml"
12/11/10 4:16:50 PM [0x0-0x25025].net.heli-x.heli-x[203] Couldn't find tag "ChatWindow" in file "/Users/adm/Library/Heli-X/files/Application/ApplicationSettings.xml"
12/11/10 4:16:53 PM [0x0-0x25025].net.heli-x.heli-x[203] Couldn't find tag "Resolution" in file "/Users/adm/Library/Heli-X/files/Application/ViewSettings.xml"
12/11/10 4:16:53 PM [0x0-0x25025].net.heli-x.heli-x[203] Using openGLLayer JOGL_AWT
12/11/10 4:16:53 PM [0x0-0x25025].net.heli-x.heli-x[203] Found 17 display modes
12/11/10 4:16:54 PM [0x0-0x25025].net.heli-x.heli-x[203] Controller found: Name: PPM(PPM)
12/11/10 4:16:54 PM [0x0-0x25025].net.heli-x.heli-x[203] Using Stick PPM
12/11/10 4:16:54 PM [0x0-0x25025].net.heli-x.heli-x[203] Digital component found:0
12/11/10 4:16:54 PM [0x0-0x25025].net.heli-x.heli-x[203] Digital component found:1
12/11/10 4:16:54 PM [0x0-0x25025].net.heli-x.heli-x[203] Digital component found:2
12/11/10 4:16:54 PM [0x0-0x25025].net.heli-x.heli-x[203] Digital component found:3
12/11/10 4:16:54 PM [0x0-0x25025].net.heli-x.heli-x[203] Digital component found:4
12/11/10 4:16:54 PM [0x0-0x25025].net.heli-x.heli-x[203] Digital component found:5
12/11/10 4:16:54 PM [0x0-0x25025].net.heli-x.heli-x[203] Digital component found:6
12/11/10 4:16:54 PM [0x0-0x25025].net.heli-x.heli-x[203] Digital component found:7
12/11/10 4:16:54 PM [0x0-0x25025].net.heli-x.heli-x[203] Digital component found:8
12/11/10 4:16:54 PM [0x0-0x25025].net.heli-x.heli-x[203] Digital component found:9
12/11/10 4:16:54 PM [0x0-0x25025].net.heli-x.heli-x[203] Digital component found:10
12/11/10 4:16:54 PM [0x0-0x25025].net.heli-x.heli-x[203] Digital component found:11
12/11/10 4:16:54 PM [0x0-0x25025].net.heli-x.heli-x[203] Analog component found:z
12/11/10 4:16:54 PM [0x0-0x25025].net.heli-x.heli-x[203] Analog component found:rz
12/11/10 4:16:54 PM [0x0-0x25025].net.heli-x.heli-x[203] Analog component found:x
12/11/10 4:16:54 PM [0x0-0x25025].net.heli-x.heli-x[203] Analog component found:y
12/11/10 4:16:54 PM [0x0-0x25025].net.heli-x.heli-x[203] Analog component found:rx
12/11/10 4:16:54 PM [0x0-0x25025].net.heli-x.heli-x[203] Analog component found:ry
12/11/10 4:16:54 PM [0x0-0x25025].net.heli-x.heli-x[203] Digital component found:pov
12/11/10 4:16:54 PM [0x0-0x25025].net.heli-x.heli-x[203] Controller configuration file not found: /Users/adm/Library/Heli-X/files/controller/PPM.xml
12/11/10 4:16:55 PM [0x0-0x25025].net.heli-x.heli-x[203] Exception in thread "AWT-EventQueue-0" java.lang.AbstractMethodError: org.apache.xerces.dom.DeferredElementImpl.getTextContent()Ljava/lang/String;
12/11/10 4:16:55 PM [0x0-0x25025].net.heli-x.heli-x[203] at a.a.a.s.t.a(Unknown Source)
12/11/10 4:16:55 PM [0x0-0x25025].net.heli-x.heli-x[203] at a.a.a.x.b.a(Unknown Source)
12/11/10 4:16:55 PM [0x0-0x25025].net.heli-x.heli-x[203] at a.a.a.x.b.c(Unknown Source)
12/11/10 4:16:55 PM [0x0-0x25025].net.heli-x.heli-x[203] at a.a.a.x.b.<init>(Unknown Source)
12/11/10 4:16:55 PM [0x0-0x25025].net.heli-x.heli-x[203] at a.a.a.l.g.<init>(Unknown Source)
12/11/10 4:16:55 PM [0x0-0x25025].net.heli-x.heli-x[203] at a.a.a.l.s.<init>(Unknown Source)
12/11/10 4:16:55 PM [0x0-0x25025].net.heli-x.heli-x[203] at a.a.a.l.o.<init>(Unknown Source)
12/11/10 4:16:55 PM [0x0-0x25025].net.heli-x.heli-x[203] at a.a.a.l.e.run(Unknown Source)
12/11/10 4:16:55 PM [0x0-0x25025].net.heli-x.heli-x[203] at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
12/11/10 4:16:55 PM [0x0-0x25025].net.heli-x.heli-x[203] at java.awt.EventQueue.dispatchEvent(EventQueue.java:633)
12/11/10 4:16:55 PM [0x0-0x25025].net.heli-x.heli-x[203] at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:296)
12/11/10 4:16:55 PM [0x0-0x25025].net.heli-x.heli-x[203] at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:211)
12/11/10 4:16:55 PM [0x0-0x25025].net.heli-x.heli-x[203] at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:201)
12/11/10 4:16:55 PM [0x0-0x25025].net.heli-x.heli-x[203] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:196)
12/11/10 4:16:55 PM [0x0-0x25025].net.heli-x.heli-x[203] at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:188)
12/11/10 4:16:55 PM [0x0-0x25025].net.heli-x.heli-x[203] at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
Re: OSX 10.6.5
This looks as if there was an error in an xml file. I suggest to delet the folder files in the personal libraray folder -> HELI-X30
rraith
Re: OSX 10.6.5
Post by rraith »
Leider ändert das nichts, habe ich schon getestet. Könnte es übrigens sein, daß der Update auf OSX 10.6 das Problem auslöst?
Re: OSX 10.6.5
Vielleicht mal ein Java-update machen. Wann passiert der Crash? Beim starten oder beim Drücken auf einen Button?
rraith
Re: OSX 10.6.5
Post by rraith »
Java ist neu. Wenn ich Heli-X starte, kommt zunächst der Begrüßungsdialog, dann die Sprachauswahl. Nach Wahl der Sprache erscheint der Dialog "No Joystick found" wenn kein USB-Adapter angeschlossen ist, sonst nichts. Im Begrüßungsdialog schreitet der Fortschrittsanzeiger eine Stufe fort, bleibt dann jedoch stehen bis zum Abschuß. Ist ein Joystick angeschlossen (der, mit dem es sonst funktioniert), passiert das gleiche, nur ohne den Dialog. Übrigens auch, wenn TX dran ist.
jbartels
Re: OSX 10.6.5
Post by jbartels »
läuft hier ohne problem. liegt also nicht am 10.6.5 :roll:
MfG Joachim 8-)
Kestrel 500sx
TT-Sparrowhawk XXT(RC-Car)
schubsi
Re: OSX 10.6.5
Post by schubsi »
@rraith
Eigentlich gehört mein Statement zur Klassifizierung "passt nicht", kanns mir aber nicht verkneifen, vielleicht nen doch hilfreichen Tipp abzugeben:
Selbiges Phänomen stellte ich fest, als ich versuchte, Heli-X auf nem Fujitsu Siemens PC (!) mit WinXP SP3 in Betrieb zu nehmen. JAVA auf dem neuesten Stand, jedoch war offensichtlich die OpenGL-Unterstützung des Grafikkartentreibers (Onboard-Intel) nicht ausreichend, sodass die Intitialisierung des Programmfensters fehlschlug... Auf nem HP Notebook mit moderner onboard ATI-GraKa funktionierte es auf Anhieb.
Kenne mich mit dem MAC nicht aus, vielleicht lässt sich was in der Richtung Grafikkarte/Treiber korrigieren/updaten?
Viel Erfolg!
-==[Schubsi]==-
heli-X 3.0 mit Noname USB-Adapter - 3x E-flite Blade mSR mit DX6i
Monc
Re: OSX 10.6.5
Post by Monc »
vielleicht kann ich dir helfen, es ist so das heli-x 3.0 auf meinem Macbook 5.1 OSX 10.6.6 läuft. Nur leider funktioniert meine Modelcraft RC USB nicht, aber ob sie unter einer Vorgängerversion funktioniert hätte kann ich nicht sagen, weil ich erst seit heute mit Heli-x 3.0 versuche zu spielen.
jbartels
Re: OSX 10.6.5
Post by jbartels »
mit diese Kabel:
http://www.mftech.de/usb-interface.htm# ... terface_II
gibts beim mac keine problem und alle schalter gehen.
MfG Joachim 8-)
Kestrel 500sx
rraith
Re: OSX 10.6.5
Post by rraith »
Leider geht es immer noch nicht, trotz Update auf neuestes Java (März 11). Am Interface liegt es definitiv nicht, funktioniert mit der 0.9 er Version von Helix, wird ja laut Console-output auch erkannt. Weiß nicht mehr weiter...
