Controller setup problems - Esky 0406A
Posted: 18 Oct 2010 06:57
I have installed Heli-X 3.0 on OSX (MacBook Pro). I have a mile high wings usb dongle connected to my Esky 0406A transmitter. I have the transmitter setup for no pitch mixing (90 degree swash plate) and mode 2. I cannot seem to setup the controller to work properly. The controls are all mixed up. On the first screen in calibration that shows all of the axis and bars, several of the bars jump around without moving any of the sticks. Also when I move a single stick (left stick up) I get several bars moving at the same time. I know the dongle works because I use it on windows with Clearview and it works fine. The end result leaves the right stick with no input received when the stick is in the lower left quadrant. Also, when I move the left stick up (increased pitch/throttle) the roll axis is affected as well. Is there a know set of configurations for my setup?
Thanks,
-Andy
Thanks,
-Andy
