openSuse 10.3 64 Bit openAL problem
Posted: 20 Aug 2008 16:10
by tom tom
hello,
i have a problem to run heli-x under OpenSuse 10.3 64Bit.
openal-0.0.8 64Bit was installed with yast.
But when i start heli-x, i get this error "openAL sound driver couldn't be found".
Under OpenSuse 10.3 32Bit on the same notebook it works perfect!
Any ideas how can i solve this problem?
Regards
tom tom
Re: openSuse 10.3 64 Bit openAL problem
Posted: 20 Aug 2008 19:12
which version of HELI-X do you use, I mean, when did you do the download? Can you please check, that the libraries are in /libs/joal/linux_amd64 ? Can you write what is in there (of which file size), e.g. ls -l
It might be, that these libs are wrong....
Posted: 20 Aug 2008 22:17
by tom tom
hello,
i did the download yesterday.
homer@client02:~/HELI-X/libs/joal/linux-amd64> ls -l
insgesamt 388
-rw-r--r-- 1 homer users 101064  1. Okt 2007  libjoal_native.so
-rw-r--r-- 1 homer users 286192  1. Okt 2007  libopenal.so
tom tom
Posted: 21 Aug 2008 20:38
it coul be that the libs are not the right ones for 64 bit. Unfortunately I do not have the right hardware to test this. Perhaps you can find an update on the web. Look for example here: http://www.lwjgl.org/download.php
Hope that helps.
