HELI-X 3.0 ubuntu unexpected exit after enabling sound
poxley100
Post by poxley100 »
I extracted HELI-X30 into a new directory /home/username/HELI-X30, started the app and entered my license details. On the next start up I enabled sound and FPV mode and restarted. On the next start the sound worked but roughly 20 seconds later the application crashed, I may also have enabled ambiance sound. I'm not sure is sound is the issue, I've tried disabling sound but the program still exits. Can you please suggest a solution?
Please see below java version and error log.
~/HELI-X30$ time sh ./runHELI-X.sh
Couldn't find tag "Resolution" in file "/home/peter/HELI-X30/files/Application/ViewSettings.xml"
ALSA lib pcm.c:2145:(snd_pcm_open_noupdate) Unknown PCM “surround51″
Couldn't find tag "AmbientSoundFile" in file "/home/peter/HELI-X30/resources/environments/Scene3D/Arctic_Zone/Arctic_Zone.xml"
Aborted
real 0m24.904s
user 0m27.718s
sys 0m1.048s
:~/HELI-X30$ which java
/usr/bin/java
~/HELI-X30$ /usr/bin/java -version
java version "1.6.0_0"
OpenJDK Runtime Environment (build 1.6.0_0-b11)
OpenJDK Server VM (build 1.6.0_0-b11, mixed mode)
Current CompileTask:
C2:941 ! a.a.a.g.e.a()La/a/a/g/e; (34 bytes)
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x8c41f000 JavaThread "TimerQueue" daemon [_thread_blocked, id=22213, stack(0x8d56f000,0x8d5c0000)]
0x083b5c00 JavaThread "Xith3D render thread" [_thread_blocked, id=22211, stack(0x90332000,0x90383000)]
0x0840d000 JavaThread "Thread-5" [_thread_blocked, id=22209, stack(0x90383000,0x903d4000)]
0x91bbe400 JavaThread "Thread-3" daemon [_thread_blocked, id=22205, stack(0x9242d000,0x9247e000)]
0x92338400 JavaThread "DestroyJavaVM" [_thread_blocked, id=22183, stack(0xb7276000,0xb72c7000)]
0x926d0400 JavaThread "AWT-EventQueue-0" [_thread_in_Java, id=22203, stack(0x9247e000,0x924cf000)]
0x92316c00 JavaThread "AWT-Shutdown" [_thread_blocked, id=22202, stack(0x930af000,0x93100000)]
0x93136000 JavaThread "AWT-XAWT" daemon [_thread_blocked, id=22197, stack(0x93202000,0x93253000)]
0x937c7000 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=22196, stack(0x93349000,0x9339a000)]
0x93701000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=22194, stack(0x93879000,0x938ca000)]
0x0812a000 JavaThread "CompilerThread1" daemon [_thread_in_native, id=22193, stack(0x938ca000,0x9394b000)]
=>0x08127800 JavaThread "CompilerThread0" daemon [_thread_in_native, id=22192, stack(0x9394b000,0x939cc000)]
0x08126800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=22191, stack(0x939cc000,0x93a1d000)]
0x0810c400 JavaThread "Finalizer" daemon [_thread_blocked, id=22190, stack(0x93a5c000,0x93aad000)]
0x08108000 JavaThread "Reference Handler" daemon [_thread_blocked, id=22189, stack(0x93aad000,0x93afe000)]
Other Threads:
0x08104c00 VMThread [stack: 0x93afe000,0x93b7f000] [id=22188]
0x93702c00 WatcherThread [stack: 0x9367f000,0x93700000] [id=22195]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
PSYoungGen total 33856K, used 14123K [0xb1690000, 0xb4130000, 0xb4130000)
eden space 23808K, 48% used [0xb1690000,0xb21e6278,0xb2dd0000)
from space 10048K, 25% used [0xb3760000,0xb39d4cf8,0xb4130000)
to space 9792K, 0% used [0xb2dd0000,0xb2dd0000,0xb3760000)
PSOldGen total 42688K, used 19287K [0x9c130000, 0x9eae0000, 0xb1690000)
object space 42688K, 45% used [0x9c130000,0x9d405c10,0x9eae0000)
PSPermGen total 34816K, used 23957K [0x94130000, 0x96330000, 0x9c130000)
object space 34816K, 68% used [0x94130000,0x958956d0,0x96330000)
Dynamic libraries:
08048000-08051000 r-xp 00000000 08:05 360335 /usr/lib/jvm/java-6-openjdk/jre/bin/java
08051000-08052000 rw-p 00009000 08:05 360335 /usr/lib/jvm/java-6-openjdk/jre/bin/java
08052000-09cd7000 rw-p 08052000 00:00 0 [heap]
85b00000-85bff000 rw-p 85b00000 00:00 0
85bff000-85c00000 ---p 85bff000 00:00 0
85c00000-85c29000 rw-p 85c00000 00:00 0
85c29000-85d00000 ---p 85c29000 00:00 0
85d00000-85dfd000 rw-p 85d00000 00:00 0
85dfd000-85e00000 ---p 85dfd000 00:00 0
85e00000-85ef9000 rw-p 85e00000 00:00 0
85ef9000-85f00000 ---p 85ef9000 00:00 0
85f00000-85fea000 rw-p 85f00000 00:00 0
85fea000-86000000 ---p 85fea000 00:00 0
86000000-860e3000 rw-p 86000000 00:00 0
860e3000-86100000 ---p 860e3000 00:00 0
86100000-861fd000 rw-p 86100000 00:00 0
861fd000-86200000 ---p 861fd000 00:00 0
86200000-862ed000 rw-p 86200000 00:00 0
862ed000-86300000 ---p 862ed000 00:00 0
86300000-86500000 rw-s 2bc8e000 00:0e 21146 /dev/nvidia0
86500000-865fe000 rw-p 86500000 00:00 0
865fe000-86600000 ---p 865fe000 00:00 0
8665f000-86be2000 rw-p 8665f000 00:00 0
86c00000-86cf9000 rw-p 86c00000 00:00 0
86cf9000-86d00000 ---p 86cf9000 00:00 0
86df0000-8b3f9000 rw-p 86df0000 00:00 0
8b3f9000-8b400000 ---p 8b3f9000 00:00 0
8b400000-8b4ff000 rw-p 8b400000 00:00 0
8b4ff000-8b500000 ---p 8b4ff000 00:00 0
8b500000-8b5f9000 rw-p 8b500000 00:00 0
8b5f9000-8b600000 ---p 8b5f9000 00:00 0
8b600000-8b6fd000 rw-p 8b600000 00:00 0
8b6fd000-8b700000 ---p 8b6fd000 00:00 0
8b700000-8b7e6000 rw-p 8b700000 00:00 0
8b7e6000-8b800000 ---p 8b7e6000 00:00 0
8b830000-8c0fe000 rw-p 8b830000 00:00 0
8c17c000-8c500000 rw-p 8c17c000 00:00 0
8c5ff000-8c700000 rw-p 8c5ff000 00:00 0
8c700000-8c900000 rw-s 32204000 00:0e 21146 /dev/nvidia0
8c900000-8c9fd000 rw-p 8c900000 00:00 0
8c9fd000-8ca00000 ---p 8c9fd000 00:00 0
8ca00000-8cb00000 rw-s 326b9000 00:0e 21146 /dev/nvidia0
8cb00000-8cbf5000 rw-p 8cb00000 00:00 0
8cbf5000-8cc00000 ---p 8cbf5000 00:00 0
8cc34000-8cfe0000 rw-p 8cc34000 00:00 0
8cfe0000-8d000000 ---p 8cfe0000 00:00 0
8d000000-8d0dd000 rw-p 8d000000 00:00 0
8d0dd000-8d100000 ---p 8d0dd000 00:00 0
8d13e000-8d2fa000 rw-p 8d13e000 00:00 0
8d2fa000-8d300000 ---p 8d2fa000 00:00 0
8d362000-8d500000 rw-p 8d362000 00:00 0
8d56f000-8d572000 ---p 8d56f000 00:00 0
8d572000-8d5c0000 rwxp 8d572000 00:00 0
8d5c0000-8d600000 rw-s 33811000 00:0e 21146 /dev/nvidia0
8d600000-8d6f0000 rw-p 8d600000 00:00 0
8d6f0000-8d700000 ---p 8d6f0000 00:00 0
8d72f000-8d793000 rw-p 00000000 00:0e 1098 /dev/zero
8d793000-8d796000 rwxp 8d793000 00:00 0
8d796000-8d7e4000 rwxp 8d796000 00:00 0
8d7e4000-902ff000 rw-p 8d7e4000 00:00 0
902ff000-90300000 ---p 902ff000 00:00 0
90332000-90335000 ---p 90332000 00:00 0
90335000-90383000 rwxp 90335000 00:00 0
90383000-90386000 ---p 90383000 00:00 0
90386000-903d4000 rwxp 90386000 00:00 0
903d4000-903d5000 ---p 903d4000 00:00 0
903d5000-90bd5000 rwxp 903d5000 00:00 0
90bd5000-90be8000 r-xp 00000000 fe:01 68259699 /home/peter/HELI-X30/libs/joal/linux-i586/libjoal_native.so
90be8000-90be9000 rw-p 00012000 fe:01 68259699 /home/peter/HELI-X30/libs/joal/linux-i586/libjoal_native.so
90be9000-90feb000 rw-p 90be9000 00:00 0
90feb000-91abf000 r-xp 00000000 08:05 267390 /usr/lib/libGLcore.so.169.12
91abf000-91afb000 rwxp 00ad3000 08:05 267390 /usr/lib/libGLcore.so.169.12
91afb000-91b00000 rwxp 91afb000 00:00 0
91b00000-91bfd000 rw-p 91b00000 00:00 0
91bfd000-91c00000 ---p 91bfd000 00:00 0
91c00000-91d00000 rw-p 91c00000 00:00 0
91d00000-91e00000 rw-p 91d00000 00:00 0
91e03000-91e25000 rw-s 00000000 00:09 0 /SYSV00000000 (deleted)
91e25000-91ee4000 r-xp 00000000 08:05 262801 /usr/lib/libasound.so.2.0.0
91ee4000-91ee8000 rw-p 000be000 08:05 262801 /usr/lib/libasound.so.2.0.0
91ee8000-91f2d000 r-xp 00000000 fe:01 68259700 /home/peter/HELI-X30/libs/joal/linux-i586/libopenal.so
91f2d000-91f2e000 rw-p 00044000 fe:01 68259700 /home/peter/HELI-X30/libs/joal/linux-i586/libopenal.so
91f2e000-91f32000 rw-p 91f2e000 00:00 0
91f32000-9200d000 r-xp 00000000 fe:01 68259721 /home/peter/HELI-X30/libs/jogl/linux-i586/libjogl.so
9200d000-9200e000 rw-p 000da000 fe:01 68259721 /home/peter/HELI-X30/libs/jogl/linux-i586/libjogl.so
9200e000-921b8000 rw-p 9200e000 00:00 0
921bf000-921c9000 rw-s 00000000 00:09 422019203 /SYSV00000000 (deleted)
921c9000-921d8000 r-xp 00000000 08:05 478500 /lib/tls/i686/cmov/libresolv-2.7.so
921d8000-921da000 rw-p 0000f000 08:05 478500 /lib/tls/i686/cmov/libresolv-2.7.so
921da000-921dc000 rw-p 921da000 00:00 0
921dc000-921fb000 r-xp 00000000 08:05 263259 /usr/lib/libjpeg.so.62.0.0
921fb000-921fc000 rw-p 0001e000 08:05 263259 /usr/lib/libjpeg.so.62.0.0
921fc000-92284000 r-xp 00000000 08:05 267389 /usr/lib/libGL.so.169.12
92284000-9229f000 rwxp 00087000 08:05 267389 /usr/lib/libGL.so.169.12
9229f000-922a0000 rwxp 9229f000 00:00 0
922a0000-92300000 rw-s 00000000 00:09 420315243 /SYSV00000000 (deleted)
92300000-923fe000 rw-p 92300000 00:00 0
923fe000-92400000 ---p 923fe000 00:00 0
92403000-92407000 r-xp 00000000 08:05 478493 /lib/tls/i686/cmov/libnss_dns-2.7.so
92407000-92409000 rw-p 00003000 08:05 478493 /lib/tls/i686/cmov/libnss_dns-2.7.so
92410000-92411000 rw-s 00000000 00:09 421494912 /SYSV00000000 (deleted)
92411000-92412000 rw-s 00000000 00:09 421462124 /SYSV00000000 (deleted)
92412000-92416000 rw-s 32195000 00:0e 21146 /dev/nvidia0
92416000-9241a000 rw-s 32631000 00:0e 21146 /dev/nvidia0
9241a000-9241b000 rw-s e0731000 00:0e 21146 /dev/nvidia0
9241b000-9241c000 rw-s 33959000 00:0e 21146 /dev/nvidia0
9241c000-9241d000 rw-s 2b870000 00:0e 21146 /dev/nvidia0
9241d000-9241e000 rw-s fac0a000 00:0e 21146 /dev/nvidia0
9241e000-9241f000 rw-s fa641000 00:0e 21146 /dev/nvidia0
9241f000-92420000 rw-s 344b3000 00:0e 21146 /dev/nvidia0
92425000-92428000 r-xp 00000000 fe:01 68259682 /home/peter/HELI-X30/libs/jinput/linux-i586/libjinput-linux.so
92428000-92429000 rw-p 00002000 fe:01 68259682 /home/peter/HELI-X30/libs/jinput/linux-i586/libjinput-linux.so
92429000-9242a000 r-xp 00000000 fe:01 68259722 /home/peter/HELI-X30/libs/jogl/linux-i586/libjogl_awt.so
9242a000-9242b000 rw-p 00000000 fe:01 68259722 /home/peter/HELI-X30/libs/jogl/linux-i586/libjogl_awt.so
9242b000-9242c000 r-xp 00000000 08:05 338203 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libjawt.so
9242c000-9242d000 rw-p 00000000 08:05 338203 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libjawt.so
9242d000-92430000 ---p 9242d000 00:00 0
92430000-9247e000 rwxp 92430000 00:00 0
9247e000-92481000 ---p 9247e000 00:00 0
92481000-924cf000 rwxp 92481000 00:00 0
924cf000-924f8000 r-xp 00000000 08:05 338208 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/liblcms.so
924f8000-924fa000 rw-p 00028000 08:05 338208 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/liblcms.so
924fa000-926d3000 rw-p 924fa000 00:00 0
926d3000-92700000 ---p 926d3000 00:00 0
92700000-92701000 rw-s 00000000 00:09 421298298 /SYSV00000000 (deleted)
92701000-92702000 rw-s fa060000 00:0e 21146 /dev/nvidia0
92702000-92704000 r-xp 00000000 08:05 457055 /lib/libnss_mdns4_minimal.so.2
92704000-92705000 rw-p 00001000 08:05 457055 /lib/libnss_mdns4_minimal.so.2
92705000-92709000 r-xp 00000000 08:05 262780 /usr/lib/libXxf86vm.so.1.0.0
92709000-9270a000 rw-p 00003000 08:05 262780 /usr/lib/libXxf86vm.so.1.0.0
9270a000-9270c000 rwxp 00000000 00:0e 1098 /dev/zero
9270c000-9270d000 r-xp 00000000 08:05 269236 /usr/lib/libnvidia-tls.so.169.12
9270d000-9270e000 rw-p 00000000 08:05 269236 /usr/lib/libnvidia-tls.so.169.12
9270e000-92717000 r-xp 00000000 08:05 338205 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libjpeg.so
92717000-92718000 rw-p 00008000 08:05 338205 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libjpeg.so
92718000-9271a000 r-xp 00000000 08:05 326415 /usr/lib/pango/1.6.0/modules/pango-basic-fc.so
9271a000-9271b000 rw-p 00001000 08:05 326415 /usr/lib/pango/1.6.0/modules/pango-basic-fc.so
9271b000-927ac000 r--p 00000000 08:05 385746 /usr/share/fonts/truetype/ttf-dejavu/DejaVuSans.ttf
927ac000-927b2000 r--s 00000000 08:05 558779 /var/cache/fontconfig/945677eb7aeaf62f1d50efc3fb3ec7d8-x86.cache-2
927b2000-927b5000 r--s 00000000 08:05 561634 /var/cache/fontconfig/e383d7ea5fbe662a33d9b44caf393297-x86.cache-2
927b5000-927b6000 r--s 00000000 08:05 561631 /var/cache/fontconfig/c69f04ab05004e31a6d5e715764f16d8-x86.cache-2
927b6000-927ba000 r--s 00000000 08:05 561629 /var/cache/fontconfig/926e794c3d5e5dffcaf2fa83ef8d36c2-x86.cache-2
927ba000-927bb000 r--s 00000000 08:05 561628 /var/cache/fontconfig/4c73fe0c47614734b17d736dbde7580a-x86.cache-2
927bb000-927be000 r--s 00000000 08:05 561627 /var/cache/fontconfig/a755afe4a08bf5b97852ceb7400b47bc-x86.cache-2
927be000-927c5000 r--s 00000000 08:05 561626 /var/cache/fontconfig/6d41288fd70b0be22e8c3a91e032eec0-x86.cache-2
927c5000-927c8000 r--s 00000000 08:05 561624 /var/cache/fontconfig/de156ccd2eddbdc19d37a45b8b2aac9c-x86.cache-2
927c8000-927d0000 r--s 00000000 08:05 561622 /var/cache/fontconfig/e3de0de479f42330eadf588a55fb5bf4-x86.cache-2
927d0000-927d8000 r--s 00000000 08:05 561620 /var/cache/fontconfig/0f34bcd4b6ee430af32735b75db7f02b-x86.cache-2
927d8000-927fa000 r--s 00000000 08:05 561618 /var/cache/fontconfig/365b55f210c0a22e9a19e35191240f32-x86.cache-2
927fa000-927fd000 r--s 00000000 08:05 561616 /var/cache/fontconfig/de9486f0b47a4d768a594cb4198cb1c6-x86.cache-2
927fd000-92804000 r--s 00000000 08:05 561614 /var/cache/fontconfig/d52a8644073d54c13679302ca1180695-x86.cache-2
92804000-9280a000 r--s 00000000 08:05 554948 /var/cache/fontconfig/089dead882dea3570ffc31a9898cfb69-x86.cache-2
9280a000-92811000 r-xp 00000000 08:05 338212 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libnio.so
92811000-92812000 rw-p 00006000 08:05 338212 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libnio.so
92812000-92825000 r-xp 00000000 08:05 338211 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libnet.so
92825000-92826000 rw-p 00013000 08:05 338211 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libnet.so
92826000-92907000 r--p 00000000 08:05 287667 /usr/lib/locale/en_GB.utf8/LC_COLLATE
92907000-92926000 r-xp 00000000 08:05 262966 /usr/lib/libexpat.so.1.5.2
92926000-92928000 rw-p 0001e000 08:05 262966 /usr/lib/libexpat.so.1.5.2
92928000-92a10000 r-xp 00000000 08:05 262363 /usr/lib/libstdc++.so.6.0.9
92a10000-92a13000 r--p 000e8000 08:05 262363 /usr/lib/libstdc++.so.6.0.9
92a13000-92a15000 rw-p 000eb000 08:05 262363 /usr/lib/libstdc++.so.6.0.9
92a15000-92a1b000 rw-p 92a15000 00:00 0
92a1b000-92a43000 r-xp 00000000 08:05 263398 /usr/lib/libpixman-1.so.0.10.0
92a43000-92a44000 rw-p 00027000 08:05 263398 /usr/lib/libpixman-1.so.0.10.0
92a44000-92a66000 r-xp 00000000 08:05 263402 /usr/lib/libpng12.so.0.15.0
92a66000-92a67000 rw-p 00022000 08:05 263402 /usr/lib/libpng12.so.0.15.0
92a67000-92a8d000 r-xp 00000000 08:05 261823 /usr/lib/libpcre.so.3.12.1
92a8d000-92a8e000 rw-p 00026000 08:05 261823 /usr/lib/libpcre.so.3.12.1
92a8e000-92ab4000 r-xp 00000000 08:05 264950 /usr/lib/libpangoft2-1.0.so.0.2002.3
92ab4000-92ab5000 rw-p 00026000 08:05 264950 /usr/lib/libpangoft2-1.0.so.0.2002.3
92ab5000-92ade000 r-xp 00000000 08:05 262974 /usr/lib/libfontconfig.so.1.3.0
92ade000-92adf000 rw-p 00029000 08:05 262974 /usr/lib/libfontconfig.so.1.3.0
92adf000-92b3f000 r-xp 00000000 08:05 266693 /usr/lib/libcairo.so.2.17.3
92b3f000-92b41000 rw-p 0005f000 08:05 266693 /usr/lib/libcairo.so.2.17.3
92b41000-92bf1000 r-xp 00000000 08:05 262934 /usr/lib/libglib-2.0.so.0.1600.6
92bf1000-92bf2000 rw-p 000b0000 08:05 262934 /usr/lib/libglib-2.0.so.0.1600.6
92bf2000-92c2d000 r-xp 00000000 08:05 263253 /usr/lib/libgobject-2.0.so.0.1600.6
92c2d000-92c2e000 rw-p 0003b000 08:05 263253 /usr/lib/libgobject-2.0.so.0.1600.6
92c2e000-92c46000 r-xp 00000000 08:05 262807 /usr/lib/libatk-1.0.so.0.2209.1
92c46000-92c48000 rw-p 00018000 08:05 262807 /usr/lib/libatk-1.0.so.0.2209.1
92c48000-92c83000 r-xp 00000000 08:05 264946 /usr/lib/libpango-1.0.so.0.2002.3
92c83000-92c85000 rw-p 0003a000 08:05 264946 /usr/lib/libpango-1.0.so.0.2002.3
92c85000-92d06000 r-xp 00000000 08:05 263221 /usr/lib/libgdk-x11-2.0.so.0.1200.9
92d06000-92d09000 rw-p 00080000 08:05 263221 /usr/lib/libgdk-x11-2.0.so.0.1200.9
92d09000-92d20000 r-xp 00000000 08:05 263502 /usr/lib/libgdk_pixbuf-2.0.so.0.1200.9
92d20000-92d21000 rw-p 00016000 08:05 263502 /usr/lib/libgdk_pixbuf-2.0.so.0.1200.9
92d21000-93091000 r-xp 00000000 08:05 264373 /usr/lib/libgtk-x11-2.0.so.0.1200.9
93091000-93097000 rw-p 00370000 08:05 264373 /usr/lib/libgtk-x11-2.0.so.0.1200.9
93097000-93098000 rw-p 93097000 00:00 0
93098000-93099000 r-xp 00000000 fe:01 68259654 /home/peter/HELI-X30/libs/gluegen/linux-i586/libgluegen-rt.so
93099000-9309a000 rw-p 00000000 fe:01 68259654 /home/peter/HELI-X30/libs/gluegen/linux-i586/libgluegen-rt.so
9309a000-9309c000 r--s 00000000 08:05 556488 /var/cache/fontconfig/e13b20fdb08344e0e664864cc2ede53d-x86.cache-2
9309c000-930ae000 r-xp 00000000 08:05 286469 /usr/lib/gtk-2.0/2.10.0/engines/libmurrine.so
930ae000-930af000 rw-p 00012000 08:05 286469 /usr/lib/gtk-2.0/2.10.0/engines/libmurrine.so
930af000-930b2000 ---p 930af000 00:00 0
930b2000-93100000 rwxp 930b2000 00:00 0
93100000-93200000 rw-p 93100000 00:00 0
93200000-93201000 r--s 00000000 08:05 561619 /var/cache/fontconfig/4794a0821666d79190d59a36cb4f44b5-x86.cache-2
93201000-93202000 r--p 00000000 08:05 507987 /usr/share/locale-langpack/en_GB/LC_MESSAGES/glib20.mo
93202000-93205000 ---p 93202000 00:00 0
93205000-93253000 rwxp 93205000 00:00 0
93253000-93259000 r--s 00000000 08:05 558779 /var/cache/fontconfig/945677eb7aeaf62f1d50efc3fb3ec7d8-x86.cache-2
93259000-9325c000 r--s 00000000 08:05 561634 /var/cache/fontconfig/e383d7ea5fbe662a33d9b44caf393297-x86.cache-2
9325c000-93260000 r--s 00000000 08:05 561629 /var/cache/fontconfig/926e794c3d5e5dffcaf2fa83ef8d36c2-x86.cache-2
93260000-93263000 r--s 00000000 08:05 561627 /var/cache/fontconfig/a755afe4a08bf5b97852ceb7400b47bc-x86.cache-2
93263000-9326a000 r--s 00000000 08:05 561626 /var/cache/fontconfig/6d41288fd70b0be22e8c3a91e032eec0-x86.cache-2
9326a000-9326d000 r--s 00000000 08:05 561624 /var/cache/fontconfig/de156ccd2eddbdc19d37a45b8b2aac9c-x86.cache-2
9326d000-9328f000 r--s 00000000 08:05 561618 /var/cache/fontconfig/365b55f210c0a22e9a19e35191240f32-x86.cache-2
9328f000-93290000 r--p 00000000 08:05 511736 /usr/share/locale-langpack/en_GB/LC_MESSAGES/libc.mo
93290000-93293000 r--p 00000000 08:05 508112 /usr/share/locale-langpack/en_GB/LC_MESSAGES/gtk20-properties.mo
93293000-93298000 r--p 00000000 08:05 508072 /usr/share/locale-langpack/en_GB/LC_MESSAGES/gtk20.mo
93298000-93299000 r--p 00000000 08:05 287673 /usr/lib/locale/en_GB.utf8/LC_NUMERIC
93299000-9329a000 r--p 00000000 08:05 287676 /usr/lib/locale/en_GB.utf8/LC_TIME
9329a000-9329b000 r--p 00000000 08:05 287671 /usr/lib/locale/en_GB.utf8/LC_MONETARY
9329b000-9329c000 r--p 00000000 08:05 287677 /usr/lib/locale/en_GB.utf8/LC_MESSAGES/SYS_LC_MESSAGES
9329c000-9329d000 r--p 00000000 08:05 287674 /usr/lib/locale/en_GB.utf8/LC_PAPER
9329d000-932a2000 r-xp 00000000 08:05 262764 /usr/lib/libXrandr.so.2.1.0
932a2000-932a3000 rw-p 00005000 08:05 262764 /usr/lib/libXrandr.so.2.1.0
932a3000-932a7000 r-xp 00000000 08:05 262746 /usr/lib/libXfixes.so.3.1.0
932a7000-932a8000 rw-p 00003000 08:05 262746 /usr/lib/libXfixes.so.3.1.0
932a8000-932af000 r-xp 00000000 08:05 262766 /usr/lib/libXrender.so.1.3.0
932af000-932b0000 rw-p 00007000 08:05 262766 /usr/lib/libXrender.so.1.3.0
932b0000-932b6000 r--s 00000000 08:05 558779 /var/cache/fontconfig/945677eb7aeaf62f1d50efc3fb3ec7d8-x86.cache-2
932b6000-932b9000 r--s 00000000 08:05 561634 /var/cache/fontconfig/e383d7ea5fbe662a33d9b44caf393297-x86.cache-2
932b9000-932ba000 r--s 00000000 08:05 561631 /var/cache/fontconfig/c69f04ab05004e31a6d5e715764f16d8-x86.cache-2
932ba000-932be000 r--s 00000000 08:05 561629 /var/cache/fontconfig/926e794c3d5e5dffcaf2fa83ef8d36c2-x86.cache-2
932be000-932bf000 r--s 00000000 08:05 561628 /var/cache/fontconfig/4c73fe0c47614734b17d736dbde7580a-x86.cache-2
932bf000-932c2000 r--s 00000000 08:05 561627 /var/cache/fontconfig/a755afe4a08bf5b97852ceb7400b47bc-x86.cache-2
932c2000-932c9000 r--s 00000000 08:05 561626 /var/cache/fontconfig/6d41288fd70b0be22e8c3a91e032eec0-x86.cache-2
932c9000-932cc000 r--s 00000000 08:05 561624 /var/cache/fontconfig/de156ccd2eddbdc19d37a45b8b2aac9c-x86.cache-2
932cc000-932d4000 r--s 00000000 08:05 561622 /var/cache/fontconfig/e3de0de479f42330eadf588a55fb5bf4-x86.cache-2
932d4000-932dc000 r--s 00000000 08:05 561620 /var/cache/fontconfig/0f34bcd4b6ee430af32735b75db7f02b-x86.cache-2
932dc000-932fe000 r--s 00000000 08:05 561618 /var/cache/fontconfig/365b55f210c0a22e9a19e35191240f32-x86.cache-2
932fe000-932ff000 r--p 00000000 08:05 287672 /usr/lib/locale/en_GB.utf8/LC_NAME
932ff000-93300000 r--p 00000000 08:05 287666 /usr/lib/locale/en_GB.utf8/LC_ADDRESS
93300000-93308000 r--s 00000000 08:05 561622 /var/cache/fontconfig/e3de0de479f42330eadf588a55fb5bf4-x86.cache-2
93308000-93309000 r--p 00000000 08:05 287675 /usr/lib/locale/en_GB.utf8/LC_TELEPHONE
93309000-9330a000 r--p 00000000 08:05 287670 /usr/lib/locale/en_GB.utf8/LC_MEASUREMENT
9330a000-9330b000 r--p 00000000 08:05 287669 /usr/lib/locale/en_GB.utf8/LC_IDENTIFICATION
9330b000-93313000 r-xp 00000000 08:05 262736 /usr/lib/libXcursor.so.1.0.2
93313000-93314000 rw-p 00007000 08:05 262736 /usr/lib/libXcursor.so.1.0.2
93314000-93316000 r-xp 00000000 08:05 262754 /usr/lib/libXinerama.so.1.0.0
93316000-93317000 rw-p 00001000 08:05 262754 /usr/lib/libXinerama.so.1.0.0
93317000-9331a000 r-xp 00000000 08:05 263251 /usr/lib/libgmodule-2.0.so.0.1600.6
9331a000-9331b000 rw-p 00002000 08:05 263251 /usr/lib/libgmodule-2.0.so.0.1600.6
9331b000-9331d000 r-xp 00000000 08:05 262738 /usr/lib/libXdamage.so.1.1.0
9331d000-9331e000 rw-p 00001000 08:05 262738 /usr/lib/libXdamage.so.1.1.0
9331e000-93320000 r-xp 00000000 08:05 262734 /usr/lib/libXcomposite.so.1.0.0
93320000-93321000 rw-p 00001000 08:05 262734 /usr/lib/libXcomposite.so.1.0.0
93321000-93329000 r-xp 00000000 08:05 264948 /usr/lib/libpangocairo-1.0.so.0.2002.3
93329000-9332a000 rw-p 00008000 08:05 264948 /usr/lib/libpangocairo-1.0.so.0.2002.3
9332a000-9332b000 r--p 9332a000 00:00 0
9332b000-93332000 r--s 000fd000 08:05 294579 /usr/lib/jvm/java-6-openjdk/jre/lib/resources.jar
93332000-93333000 r--s 00000000 08:05 561631 /var/cache/fontconfig/c69f04ab05004e31a6d5e715764f16d8-x86.cache-2
93333000-93334000 r--s 00000000 08:05 561628 /var/cache/fontconfig/4c73fe0c47614734b17d736dbde7580a-x86.cache-2
93334000-9333c000 r--s 00000000 08:05 561620 /var/cache/fontconfig/0f34bcd4b6ee430af32735b75db7f02b-x86.cache-2
9333c000-93343000 r--s 00000000 08:05 561614 /var/cache/fontconfig/d52a8644073d54c13679302ca1180695-x86.cache-2
93343000-93349000 r--s 00000000 08:05 554948 /var/cache/fontconfig/089dead882dea3570ffc31a9898cfb69-x86.cache-2
93349000-9334c000 ---p 93349000 00:00 0
9334c000-9339a000 rwxp 9334c000 00:00 0
9339a000-933a4000 r-xp 00000000 08:05 460152 /lib/libgcc_s.so.1
933a4000-933a5000 rw-p 0000a000 08:05 460152 /lib/libgcc_s.so.1
933a5000-9340f000 r-xp 00000000 08:05 265351 /usr/lib/libfreetype.so.6.3.16
9340f000-93412000 rw-p 0006a000 08:05 265351 /usr/lib/libfreetype.so.6.3.16
93412000-93455000 r-xp 00000000 08:05 338193 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libfontmanager.so
93455000-93457000 rw-p 00043000 08:05 338193 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libfontmanager.so
93457000-9345b000 rw-p 93457000 00:00 0
9345b000-9345f000 r-xp 00000000 08:05 262740 /usr/lib/libXdmcp.so.6.0.0
9345f000-93460000 rw-p 00003000 08:05 262740 /usr/lib/libXdmcp.so.6.0.0
93460000-93477000 r-xp 00000000 08:05 263570 /usr/lib/libxcb.so.1.0.0
93477000-93478000 rw-p 00016000 08:05 263570 /usr/lib/libxcb.so.1.0.0
93478000-9347a000 r-xp 00000000 08:05 262729 /usr/lib/libXau.so.6.0.0
9347a000-9347b000 rw-p 00001000 08:05 262729 /usr/lib/libXau.so.6.0.0
9347b000-93482000 r-xp 00000000 08:05 262752 /usr/lib/libXi.so.6.0.0
93482000-93483000 rw-p 00006000 08:05 262752 /usr/lib/libXi.so.6.0.0
93483000-93567000 r-xp 00000000 08:05 262723 /usr/lib/libX11.so.6.2.0
93567000-9356a000 rw-p 000e4000 08:05 262723 /usr/lib/libX11.so.6.2.0
9356a000-93577000 r-xp 00000000 08:05 262744 /usr/lib/libXext.so.6.4.0
93577000-93578000 rw-p 0000d000 08:05 262744 /usr/lib/libXext.so.6.4.0
93578000-9357b000 r--s 00000000 08:05 561616 /var/cache/fontconfig/de9486f0b47a4d768a594cb4198cb1c6-x86.cache-2
9357b000-9357d000 r--s 00000000 08:05 556488 /var/cache/fontconfig/e13b20fdb08344e0e664864cc2ede53d-x86.cache-2
9357d000-93580000 r--s 00000000 08:05 561616 /var/cache/fontconfig/de9486f0b47a4d768a594cb4198cb1c6-x86.cache-2
93580000-93587000 r--s 00000000 08:05 561614 /var/cache/fontconfig/d52a8644073d54c13679302ca1180695-x86.cache-2
93587000-9358d000 r--s 00000000 08:05 554948 /var/cache/fontconfig/089dead882dea3570ffc31a9898cfb69-x86.cache-2
9358d000-9358f000 r--s 00000000 08:05 556488 /var/cache/fontconfig/e13b20fdb08344e0e664864cc2ede53d-x86.cache-2
9358f000-935d0000 r-xp 00000000 08:05 368662 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/xawt/libmawt.so
935d0000-935d2000 rw-p 00040000 08:05 368662 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/xawt/libmawt.so
935d2000-935d3000 rw-p 935d2000 00:00 0
935d3000-93654000 r-xp 00000000 08:05 338190 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libawt.so
93654000-9365b000 rw-p 00081000 08:05 338190 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libawt.so
9365b000-9367f000 rw-p 9365b000 00:00 0
9367f000-93680000 ---p 9367f000 00:00 0
93680000-93700000 rwxp 93680000 00:00 0
93700000-937fe000 rw-p 93700000 00:00 0
937fe000-93800000 ---p 937fe000 00:00 0
93800000-93801000 r--s 00000000 08:05 561619 /var/cache/fontconfig/4794a0821666d79190d59a36cb4f44b5-x86.cache-2
93801000-93802000 r--s 00000000 08:05 561619 /var/cache/fontconfig/4794a0821666d79190d59a36cb4f44b5-x86.cache-2
93802000-93804000 r--s 0000d000 fe:01 68259775 /home/peter/HELI-X30/libs/sound/jorbis-0.0.15.jar
93804000-93805000 r--s 00001000 fe:01 68259774 /home/peter/HELI-X30/libs/sound/jogg-0.0.7.jar
93805000-93806000 r--s 00003000 fe:01 68259779 /home/peter/HELI-X30/libs/xith/hud-themes.jar
93806000-9380a000 r--s 00079000 08:05 294575 /usr/lib/jvm/java-6-openjdk/jre/lib/jsse.jar
9380a000-9382a000 r--s 00282000 fe:01 68259782 /home/peter/HELI-X30/libs/xith/xith3d.jar
9382a000-93830000 r--s 000d7000 fe:01 68259770 /home/peter/HELI-X30/libs/math/openmali.jar
93830000-93835000 r--s 0002f000 fe:01 68259676 /home/peter/HELI-X30/libs/jinput/jinput.jar
93835000-9383c000 r--s 00073000 fe:01 68259753 /home/peter/HELI-X30/libs/lwjgl/lwjgl.jar
9383c000-93847000 r--s 00108000 fe:01 68259714 /home/peter/HELI-X30/libs/jogl/jogl.jar
93847000-93849000 r--s 0000b000 fe:01 68259692 /home/peter/HELI-X30/libs/joal/joal.jar
93849000-9384c000 r--s 00023000 fe:01 68259672 /home/peter/HELI-X30/libs/jdom/jdom.jar
9384c000-93857000 r--s 0004d000 fe:01 68259669 /home/peter/HELI-X30/libs/javagamenetworking/jgn.jar
93857000-93867000 r--s 000db000 fe:01 68259666 /home/peter/HELI-X30/libs/jagatoo/jagatoo.jar
93867000-93870000 r--s 0011c000 fe:01 68259662 /home/peter/HELI-X30/libs/HeliX/HeliX.jar
93870000-93879000 r--s 00065000 08:05 343148 /usr/share/java/gnome-java-bridge.jar
93879000-9387c000 ---p 93879000 00:00 0
9387c000-938ca000 rwxp 9387c000 00:00 0
938ca000-938cd000 ---p 938ca000 00:00 0
938cd000-9394b000 rwxp 938cd000 00:00 0
9394b000-9394e000 ---p 9394b000 00:00 0
9394e000-939cc000 rwxp 9394e000 00:00 0
939cc000-939cf000 ---p 939cc000 00:00 0
939cf000-93a1d000 rwxp 939cf000 00:00 0
93a1d000-93a5c000 r--p 00000000 08:05 287668 /usr/lib/locale/en_GB.utf8/LC_CTYPE
93a5c000-93a5f000 ---p 93a5c000 00:00 0
93a5f000-93aad000 rwxp 93a5f000 00:00 0
93aad000-93ab0000 ---p 93aad000 00:00 0
93ab0000-93afe000 rwxp 93ab0000 00:00 0
93afe000-93aff000 ---p 93afe000 00:00 0
93aff000-93b7f000 rwxp 93aff000 00:00 0
93b7f000-93bb1000 rw-p 93b7f000 00:00 0
93bb1000-93d40000 r--s 033bd000 08:05 294294 /usr/lib/jvm/java-6-openjdk/jre/lib/rt.jar
93d40000-93d41000 ---p 93d40000 00:00 0
93d41000-93dc1000 rwxp 93d41000 00:00 0
93dc1000-93dc2000 ---p 93dc1000 00:00 0
93dc2000-93e42000 rwxp 93dc2000 00:00 0
93e42000-93e43000 ---p 93e42000 00:00 0
93e43000-93ec3000 rwxp 93e43000 00:00 0
93ec3000-93ec4000 ---p 93ec3000 00:00 0
93ec4000-93f55000 rwxp 93ec4000 00:00 0
93f55000-93f84000 rwxp 93f55000 00:00 0
93f84000-93f99000 rwxp 93f84000 00:00 0
93f99000-9402f000 rwxp 93f99000 00:00 0
9402f000-94040000 rwxp 9402f000 00:00 0
94040000-9406f000 rwxp 94040000 00:00 0
9406f000-94084000 rwxp 9406f000 00:00 0
94084000-94119000 rwxp 94084000 00:00 0
94119000-9412f000 rwxp 94119000 00:00 0
9412f000-96330000 rwxp 9412f000 00:00 0
96330000-9c130000 rwxp 96330000 00:00 0
9c130000-9eae0000 rwxp 9c130000 00:00 0
9eae0000-b1690000 rwxp 9eae0000 00:00 0
b1690000-b4130000 rwxp b1690000 00:00 0
b4130000-b4134000 r-xp 00000000 08:05 262772 /usr/lib/libXtst.so.6.1.0
b4134000-b4135000 rw-p 00003000 08:05 262772 /usr/lib/libXtst.so.6.1.0
b4135000-b413c000 r--s 00000000 08:05 261225 /usr/lib/gconv/gconv-modules.cache
b413c000-b414a000 rwxp b413c000 00:00 0
b414a000-b41fc000 rwxp b414a000 00:00 0
b41fc000-b4564000 rwxp b41fc000 00:00 0
b4564000-b71fc000 rwxp b4564000 00:00 0
b71fc000-b7203000 r-xp 00000000 08:05 338220 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libzip.so
b7203000-b7204000 rw-p 00006000 08:05 338220 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libzip.so
b7204000-b7227000 r-xp 00000000 08:05 338201 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libjava.so
b7227000-b7229000 rw-p 00023000 08:05 338201 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libjava.so
b7229000-b7232000 r-xp 00000000 08:05 478494 /lib/tls/i686/cmov/libnss_files-2.7.so
b7232000-b7234000 rw-p 00008000 08:05 478494 /lib/tls/i686/cmov/libnss_files-2.7.so
b7234000-b723c000 r-xp 00000000 08:05 478496 /lib/tls/i686/cmov/libnss_nis-2.7.so
b723c000-b723e000 rw-p 00007000 08:05 478496 /lib/tls/i686/cmov/libnss_nis-2.7.so
b723e000-b7252000 r-xp 00000000 08:05 478491 /lib/tls/i686/cmov/libnsl-2.7.so
b7252000-b7254000 rw-p 00013000 08:05 478491 /lib/tls/i686/cmov/libnsl-2.7.so
b7254000-b7256000 rw-p b7254000 00:00 0
b7256000-b7257000 r-xp 00000000 08:05 263568 /usr/lib/libxcb-xlib.so.0.0.0
b7257000-b7258000 rw-p 00000000 08:05 263568 /usr/lib/libxcb-xlib.so.0.0.0
b7258000-b7264000 r-xp 00000000 08:05 338218 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libverify.so
b7264000-b7265000 rw-p 0000b000 08:05 338218 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libverify.so
b7265000-b726d000 rw-s 00000000 08:05 395788 /tmp/hsperfdata_peter/22182
b726d000-b7274000 r-xp 00000000 08:05 478501 /lib/tls/i686/cmov/librt-2.7.so
b7274000-b7276000 rw-p 00006000 08:05 478501 /lib/tls/i686/cmov/librt-2.7.so
b7276000-b7279000 ---p b7276000 00:00 0
b7279000-b72c7000 rwxp b7279000 00:00 0
b72c7000-b72ea000 r-xp 00000000 08:05 478489 /lib/tls/i686/cmov/libm-2.7.so
b72ea000-b72ec000 rw-p 00023000 08:05 478489 /lib/tls/i686/cmov/libm-2.7.so
b72ec000-b7938000 r-xp 00000000 08:05 359816 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/server/libjvm.so
b7938000-b7982000 rw-p 0064c000 08:05 359816 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/server/libjvm.so
b7982000-b7da4000 rw-p b7982000 00:00 0
b7da4000-b7eed000 r-xp 00000000 08:05 478485 /lib/tls/i686/cmov/libc-2.7.so
b7eed000-b7eee000 r--p 00149000 08:05 478485 /lib/tls/i686/cmov/libc-2.7.so
b7eee000-b7ef0000 rw-p 0014a000 08:05 478485 /lib/tls/i686/cmov/libc-2.7.so
b7ef0000-b7ef3000 rw-p b7ef0000 00:00 0
b7ef3000-b7ef5000 r-xp 00000000 08:05 478488 /lib/tls/i686/cmov/libdl-2.7.so
b7ef5000-b7ef7000 rw-p 00001000 08:05 478488 /lib/tls/i686/cmov/libdl-2.7.so
b7ef7000-b7efb000 r-xp 00000000 08:05 338188 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/jli/libjli.so
b7efb000-b7efc000 rw-p 00003000 08:05 338188 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/jli/libjli.so
b7efc000-b7f10000 r-xp 00000000 08:05 478499 /lib/tls/i686/cmov/libpthread-2.7.so
b7f10000-b7f12000 rw-p 00013000 08:05 478499 /lib/tls/i686/cmov/libpthread-2.7.so
b7f12000-b7f15000 rw-p b7f12000 00:00 0
b7f15000-b7f29000 r-xp 00000000 08:05 263582 /usr/lib/libz.so.1.2.3.3
b7f29000-b7f2a000 rw-p 00013000 08:05 263582 /usr/lib/libz.so.1.2.3.3
b7f2a000-b7f2d000 r--s 00017000 fe:01 68259777 /home/peter/HELI-X30/libs/sound/tritonus_share.jar
b7f2d000-b7f2e000 r--s 00004000 fe:01 68259649 /home/peter/HELI-X30/libs/gluegen/gluegen-rt.jar
b7f2e000-b7f35000 r-xp 00000000 08:05 478492 /lib/tls/i686/cmov/libnss_compat-2.7.so
b7f35000-b7f37000 rw-p 00006000 08:05 478492 /lib/tls/i686/cmov/libnss_compat-2.7.so
b7f37000-b7f3e000 r-xp 00000000 08:05 359465 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/native_threads/libhpi.so
b7f3e000-b7f3f000 rw-p 00006000 08:05 359465 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/native_threads/libhpi.so
b7f3f000-b7f40000 rwxp b7f3f000 00:00 0
b7f40000-b7f41000 r--p b7f40000 00:00 0
b7f41000-b7f43000 rw-p b7f41000 00:00 0
b7f43000-b7f44000 r-xp b7f43000 00:00 0 [vdso]
b7f44000-b7f5e000 r-xp 00000000 08:05 462215 /lib/ld-2.7.so
b7f5e000-b7f60000 rw-p 00019000 08:05 462215 /lib/ld-2.7.so
bf9cc000-bf9e1000 rwxp bffeb000 00:00 0 [stack]
VM Arguments:
jvm_args: -Xmx384m -Djava.library.path=:/home/peter/HELI-X30/libs//jogl/linux-i586/:/home/peter/HELI-X30/libs//lwjgl/linux-i586/:/home/peter/HELI-X30/libs//joal/linux-i586/:/home/peter/HELI-X30/libs//gluegen/linux-i586/:/home/peter/HELI-X30/libs//jinput/linux-i586/
java_command: HELIX
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=$HOME/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/home/peter/bin:/home/peter/bin
USERNAME=peter
LD_LIBRARY_PATH=/usr/lib/jvm/java-6-openjdk/jre/lib/i386/server:/usr/lib/jvm/java-6-openjdk/jre/lib/i386:/usr/lib/jvm/java-6-openjdk/jre/../lib/i386
SHELL=/bin/bash
DISPLAY=:0.0
Signal Handlers:
SIGSEGV: [libjvm.so+0x5e08d0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGBUS: [libjvm.so+0x5e08d0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGFPE: [libjvm.so+0x4b6e90], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGPIPE: [libjvm.so+0x4b6e90], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGXFSZ: [libjvm.so+0x4b6e90], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGILL: [libjvm.so+0x4b6e90], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGUSR1: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGUSR2: [libjvm.so+0x4b9b60], sa_mask[0]=0x00000000, sa_flags=0x10000004
SIGHUP: [libjvm.so+0x4b8630], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGINT: [libjvm.so+0x4b8630], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGTERM: [libjvm.so+0x4b8630], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGQUIT: [libjvm.so+0x4b8630], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
--------------- S Y S T E M ---------------
OS:Ubuntu 8.04 (hardy)
uname:Linux 2.6.24-23-generic #1 SMP Mon Jan 26 00:13:11 UTC 2009 i686
libc:glibc 2.7 NPTL 2.7
rlimit: STACK 8192k, CORE 0k, NPROC 16375, NOFILE 1024, AS infinity
load average:1.00 0.53 0.44
CPU:total 4 (4 cores per cpu, 1 threads per core) family 6 model 15 stepping 11, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3
Memory: 4k page, physical 2074584k(60992k free), swap 7815580k(7154972k free)
vm_info: OpenJDK Server VM (1.6.0_0-b11) for linux-x86 JRE (1.6.0_0-b11), built on Jan 30 2009 19:47:19 by "buildd" with gcc 4.1.3 20080308 (prerelease) (Ubuntu 4.1.2-21ubuntu1)
time: Wed Jul 7 07:30:26 2010
elapsed time: 24 seconds
Re: HELI-X 3.0 ubuntu unexpected exit after enabling sound
it might be that you computer has problems with the ambient sounds.
Disable them in settings->performance
quit HELI-X, and then start it again.
Phoenix
Post by Phoenix »
hi
I had the same problem that the program crashed after a few seconds. I think the problem is the openJDK.
I installed the Java Runtime Envirement from Sun and now the program runs fine.
poxley100
Post by poxley100 »
As recommended I tried the Sun version and appears to have fixed the problem!
I got the version from:
http://javadl.sun.com/webapps/download/ ... leId=39485
Many thanks,
Peter
