Heli-X VR- Can not reach menu bar with mouse.
CaptLeMay
Post by CaptLeMay »
Heli-X VR. I can activate the Menu Bar with the mouse, but the mouse stops below the Bar when trying to make selections. Can not make selections from the Menu Bar in VR. No problem on screen. What am I doing wrong?
Re: Heli-X VR- Can not reach menu bar with mouse.
Make sure the Window on the computer is viisble so that the mouse position can by analyzed
Change the menu position in VR (global settings-VR->depth) so that the plane is more away.
CaptLeMay
Post by CaptLeMay »
I tried changing the depth as you suggested. No effect.
Howe ever in the process of going back and forth between Heli-X standard and VR I ultimately noticed my resolution for VR was too high. I adjusted it down to display area screen resolution set on my computer. That solved the problem.
I have another issue I need help with.
How do I save a non-standard "Flight Mode Configuration"?
I can adjust the Flight Mode Configuration, but when I press "Save Curves", I can not enter information in the "Name" or "Comment" fields presented in the "Save stick Curves" Menu. The manual does not mention this option that I could find.
Also:
How do I switch between using the curves in my radio (TX-16) and the curves in Heli-X, or can I?
