VR settings in combination with Oculus Quest
Steber
Post by Steber »
I have a few questions regarding the VR settings.
The models quickly become very small.
I „played“ already with the object zoom but the behavior did not really change even with the object zoom of 150.
Which settings for the video size, object zoom and Mayen other settings work for you?
I am using a Oculus Quest 2 in combination with a GTX1070!
Many thanks
BR
Stefan
Re: VR settings in combination with Oculus Quest
the first question is if the angle of view is correct. Is it?
Then the problem might be to the fact that the helicopter seems to be to have more power?
The angle of view is defined by the hardware. It is not supposed to be changed by the program...
Steber
Post by Steber »
I thought that I did ;). I changed under Konfiguration/Ansicht the STD Angle of view to 80, the min angle to 70 and the max to 90. The Oculus has a horizontal angle of view of 89 and vertical angle of view of 93.
I apologize for asking stupid questions ;)
Thanks a lot!
Stefan
Steber
Post by Steber »
do you have a hint, where to change the angle of view in Heli-X?
Thanks a lot!
BR
Stefan
... this is only in non VR mode possible with the zoom keys. In VR the field of view is defined by the hardware. In fact the glasses tell HELI-X how the field of view is. I am wondering if there is going something wrong ...
Steber
Post by Steber »
wie kann man das herausfinden? Gibt es irgend ein Logfile?
Nutz noch jemand anderes die Oculus Quest? Ich mag nicht ausschließen, dass ich irgendwas falsch eingestellt habe!
Besten Dank!
Grüße Stefan
