controller :|
foxmaster
controller :|
Post by foxmaster »
Hello friends!
Iam new to this rc hobby but i got me a walkera 36 and thought i train in a sim and I found heli-x. Now for the problem,
The program starts but no reaction when I calibrate the controller. I've read the posts on the forum and the problem is most likly the permissions on the /dev/input, if I chmod them they becom writable but after a while the old mods are back ????
drwxr-xr-x 4 root root 400 2009-04-03 17:38 .
drwxr-xr-x 15 root root 14080 2009-04-03 17:38 ..
drwxr-xr-x 2 root root 120 2009-04-03 17:38 by-id
drwxr-xr-x 2 root root 200 2009-04-03 17:38 by-path
crwxrwxrwx 1 root root 13, 64 2009-04-03 17:38 event0
crwxrwxrwx 1 root root 13, 65 2009-04-03 17:38 event1
crwxrwxrwx 1 root root 13, 74 2009-04-03 17:38 event10
crwxrwxrwx 1 root root 13, 66 2009-04-03 17:38 event2
crwxrwxrwx 1 root root 13, 67 2009-04-03 17:38 event3
crwxrwxrwx 1 root root 13, 68 2009-04-03 17:38 event4
crwxrwxrwx 1 root root 13, 69 2009-04-03 17:38 event5
crwxrwxrwx 1 root root 13, 70 2009-04-03 17:38 event6
crwxrwxrwx 1 root root 13, 71 2009-04-03 17:38 event7
crwxrwxrwx 1 root root 13, 72 2009-04-03 17:38 event8
crwxrwxrwx 1 root root 13, 73 2009-04-03 17:38 event9
crwxrwxrwx 1 root plugdev 13, 0 2009-04-03 17:38 js0
and after I started the heli-x app
drwxr-xr-x 4 root root 400 2009-04-03 18:39 .
drwxr-xr-x 15 root root 14080 2009-04-03 18:39 ..
drwxr-xr-x 2 root root 120 2009-04-03 18:39 by-id
drwxr-xr-x 2 root root 200 2009-04-03 18:39 by-path
crw-rw---- 1 root root 13, 67 2009-04-03 18:39 event3
crw-rw-rwx 1 root plugdev 13, 0 2009-04-03 18:39 js0
and the log says
Set new path for the resources: /home/fox/heli/HELI-X/resources/
Set new path for the user files: /home/fox/heli/HELI-X/files/
Found 4 display modes
Loading: net.java.games.input.LinuxEnvironmentPlugin
Linux plugin claims to have found 9 controllers
Controller found: Name: ? PPM^Z^Z^Z^Z^Z^Z^Z^Z^Z^Z^Z(? PPM^Z^Z^Z^Z^Z^Z^Z^Z^Z^Z^Z)
Using Stick ? PPM^Z^Z^Z^Z^Z^Z^Z^Z^Z^Z^Z
Digital component found:Thumb
Analog component found:x
Analog component found:y
Analog component found:z
Analog component found:rx
Analog component found:ry
Controller configuration file found: /home/fox/heli/HELI-X/files/controller/PPM.xml
Controller configuration file /home/fox/heli/HELI-X/files/controller/PPM.xml read
If u can help me it would be great
/foxmaster
Re: controller :|
Hi foxmaster,
I guess, you use version 0.9 of HELI-X. Do you get the same behavior wirh version 1.1?
What Linux systen do you have?
Did you give HELI-X a try as root?
foxmaster
Re: controller :|
Post by foxmaster »
Iam using version 1.1 of Heli-x and iam on a kbuntu 8.10 system. And same result when iam root!
foxmaster
Re: controller :|
Post by foxmaster »
I Have fixed the problem with the rights in the /dev folder. Now Iam stuck on that my linux cant calibrate my controller :(
/foxmaster
foxmaster
Re: controller :|
Post by foxmaster »
What a great simulator I love it.
I got all problems fixed now. I went to a rc store and bought me a dummy usb transmitter, works great now
