Change V7 --> V8: Controller does not work
frumpy
Post by frumpy »
Hi there,
I'm using V7 and a ADCI controller (old easyfly3 USB controller, like a joystick) without problems.
After installing V8, this controller is not detected anymore. I tried the same calibration steps
as in V7, but V8 does not detect any axis movement. Win7 control panel lists the controller as working.
Why is this?
Re: Change V7 --> V8: Controller does not work
you might try different input systems (global options).
frumpy
Post by frumpy »
Thank you. I tried all available input systems, no response.
bapao76
Post by bapao76 »
Same issue here. Used to work but recently updated to V8 and now it says "no joystick found". Doesn't see any controllers at all. Have an xbox controller and a Nacon that i've tried removing from the PC and the PPM adapter that always worked in the past is not recognized either. I calibrated the PPM adapter via the Win10 control panel and it's recognized and reacts to inputs. Tried all of the global input options, restarted windows ect. Installed to the default path and there are no errors in the DOS box.
admin
Administrator
Post by admin »
Please try the 32 bit version of HELI-X 8.
frumpy
Post by frumpy »
I tried 32bit and all available input systems, no change.
Hi
the picture shows that the controller IS detected.
1. So did you go further in the calibration steps? The bars move AFTER the calibration.
2. If not, choose the factoryx settings and try again.
3. If it does not work, post the contents of the terminal window after the start of HELI-X.
frumpy
Post by frumpy »
Michael wrote: 27 Mar 2019 06:33 1. So did you go further in the calibration steps? The bars move AFTER the calibration.
That's it! Thank you, all working now.
