Page 1 of 4
Lead for transmitter
Posted: 15 Jan 2009 13:47
by Tommy_G
Hello everyone. I am new on here and new to Heli-x. I am english and can speak/read basic german. So even if you reply in German that will be great.
I have a walkera transmitter and a usb lead, but this does not seem to be recognised by Heli-x. Am i right in thinking I need a cable that converts the PPM signal to a Joystick interface??? Such as this Hitec cable:
http://www.heliguy.com/Extras/Radio-Tra ... ace-Cable/
Or are there any ways to get my usb lead to work. I believe it is one that is supposed to work with FMS. But my mac wont recognise it.
Vielen Dank
Tom
Re: Lead for transmitter
Posted: 15 Jan 2009 17:41
by Joerg
Hi Tommy,
is that USB device listed in the system profiler of OS X (Apple menu, about this Mac, More info, then select HW->USB on the left pane to get a representation of the USB device tree)?
Posted: 16 Jan 2009 12:33
by Tommy_G
Hi Joerg,
Yes it appears in the USB tree. Here is a picture.
- Picture 1.png (25.62 KiB) Viewed 30060 times
It recognises it at the start up of Heli-x, but doesn't do anything in the controller configuration?!??
Posted: 16 Jan 2009 12:37
Did you do a calibration? Left top button in the configuration window for the controller ...
Posted: 16 Jan 2009 12:53
by Tommy_G
Yeah i did the calibration. Moved sticks as asked but the corresponding bars did not move??!
Posted: 16 Jan 2009 14:55
by ustumm
Helo Tommy,
do you know the "Gamepad and Joystick tester" for Mac ?
http://alphaomega.software.free.fr/joys ... ester.html
There you can see, if the system regonize the transmitter.
If you move the sticks, you see the corresponding values received from the os.
greetings
Posted: 16 Jan 2009 16:11
by Tommy_G
Hello =]
Yeah i tried that program. This dialogue came up. But no change to numbers when sticks are moved ?!?
- Picture 2.png (42.85 KiB) Viewed 30036 times
Im not really sure what else I can do. I tried the lead on a pc. Seems to work fine and the signal from the transmitter reaches the computer fine. So im not sure why it wont work on the mac, especially as it recognises it.
Thanks once again
Tom
Posted: 16 Jan 2009 19:43
the recognition of the hardware on a PC (or MAC) depends only on the interface, not on the transmitter. So it might be, that the interface works, but the connection to the transmitter has problems. Wrong plug, cable defect, wrong programming at the transmitter etc.
Posted: 16 Jan 2009 21:22
by Joerg
Uhm - is there any (DIP) switch you need to throw when you use a Walkera TX on a sim cable? I don't use one (for simulation), so I don't really know?
Posted: 16 Jan 2009 21:29
by Tommy_G
Well it seems to work ok on a PC as is! Would I need to change dip switch settings for mac?
