Distance to "cage"
ukarlsson
Distance to "cage"
Post by ukarlsson »
Thanks for providing this software and support forum. I'm trying to train some manouvers and not float away to much in any direction, thus I'm playing around with the Training-Cage mode. It's pretty good, but the cage is way too close to the camera, it's like flying with my 500-size heli 3 m away from myself trying to do flips! Can I somehow move the cage farther away from the camera or use some other feature to practice staying in the same point while cranking away on the sticks?
Kind regards,
Re: Distance to "cage"
Post by JS1 »
The easiest way probably would be to zoom out in the view menu, if that's what you are looking for.
helicopter
Post by helicopter »
JS1 wrote:The easiest way probably would be to zoom out in the view menu, if that's what you are looking for.
i think it worth to try...
Or you can edit the xml file of the airport and change the helixopter's start position ...
In V5 this cen be done with the menu ...
