No controller found (again!)
Posted: 22 Apr 2013 19:14
I have tried several times to get HELI-X working on my Linux box, and failed. Now I have decided to try harder and get it working!
My machine is running Linux Mint 13, 32-bit.
When I start HELI-X 4.1 from the command line I get:
(note: I'm running runHELI-X_sound_padsp.sh to avoid showing the sound error message - another different issue!)
I have also tried:
'jstest /dev/input/js0' is showing that my Tx is connected and working correctly.
I have tried searching the forum, but I'm struggling - can anyone help?
david@desktop ~/HELI-X42 $ ./runHELI-X_sound_padsp.sh
Set new path for the resources: /home/david/HELI-X42/resources/
Set new path for the user files: /home/david/HELI-X42/files/
Found 12 display modes
22-Apr-2013 19:02:45 net.java.games.input.ControllerEnvironment log
INFO: Failed to open device (/dev/input/event0): Failed to open device /dev/input/event0 (13)
INFO: Failed to open device (/dev/input/event1): Failed to open device /dev/input/event1 (13)
INFO: Failed to open device (/dev/input/event2): Failed to open device /dev/input/event2 (13)
INFO: Failed to open device (/dev/input/event3): Failed to open device /dev/input/event3 (13)
java.lang.UnsatisfiedLinkError: net.java.games.input.LinuxJoystickDevice.nGetAxisMap(J)[B
at net.java.games.input.LinuxJoystickDevice.nGetAxisMap(Native Method)
at net.java.games.input.LinuxJoystickDevice.getDeviceAxisMap(LinuxJoystickDevice.java:200)
at net.java.games.input.LinuxJoystickDevice.<init>(LinuxJoystickDevice.java:70)
at net.java.games.input.LinuxEnvironmentPlugin.enumerateJoystickControllers(LinuxEnvironmentPlugin.java:408)
at net.java.games.input.LinuxEnvironmentPlugin.enumerateControllers(LinuxEnvironmentPlugin.java:235)
at net.java.games.input.LinuxEnvironmentPlugin.<init>(LinuxEnvironmentPlugin.java:115)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:532)
at java.lang.Class.newInstance0(Class.java:374)
at java.lang.Class.newInstance(Class.java:327)
at net.java.games.input.DefaultControllerEnvironment.getControllers(DefaultControllerEnvironment.java:160)
at a.a.a.n.a.r(Unknown Source)
at a.a.a.n.a.<init>(Unknown Source)
at a.a.a.g.h.W(Unknown Source)
at a.a.a.g.h.<init>(Unknown Source)
at a.a.a.m.q.<init>(Unknown Source)
at a.a.a.m.e.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:226)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:673)
at java.awt.EventQueue.access$300(EventQueue.java:96)
at java.awt.EventQueue$2.run(EventQueue.java:634)
at java.awt.EventQueue$2.run(EventQueue.java:632)
at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:105)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:643)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:275)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:200)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:185)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:177)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:138)
No Joystick found
david@desktop ~/HELI-X42 $ ls -l /dev/input/js*
crw-rw-r--+ 1 root root 13, 0 Apr 22 19:01 /dev/input/js0
