No controller found (linux)
Re: No controller found (linux)
This looks perfectly!
You just have to do an auto configuration. After that the stick movement will be visible. And: Do not click "safe", just "ok".
Taurim
Post by Taurim »
Whoa, forget everything I wrote in the last message, it works ! :oops:
The problem was that I did not understand I had first to go to auto configuration to see the gauges move in the main configuration screen !
Now, I only have to fly my virtual T-Rex. Thanks a lot ;)
PS : and I just read your answer with the solution :oops: :D
