Modeling Log: GAUI X7 for HELI-X
Re: Modeling Log: GAUI X7 for HELI-X
Post by JS1 »
velocity90
Post by velocity90 »
Very nice :D Cant wait to try it. Is it easy to change blades or is this something that isnt easy to do by myself?
Post by JS1 »
velocity90 wrote:Is it easy to change blades or is this something that isnt easy to do by myself?
Changing the looks only for yourself is easy. Just locate the texture image (MainR.jpg) in the model folder and adjust it using a paint program. Also do the same with the texture files for the spinning rotor disc (top.png and bottom.png). The spinning textures must be .png and have a suitable transparency.
But to have it changeable and available for all is a different story and basically not possible. You could define the rotors as Texture Shape and set the texture files in the .xml - BUT, even this would have no effect on switching the looks of the spinning rotor disc.
velocity90
Thank you for your answer. Adjusting using a paint program is almost inpossible for me. How do I make a proper usable file from a set of real blades ( Rail 696) or just a picture of them. What angle? All magic to me :o
Post by JS1 »
Hm, I fear that to make a usable picture file the usage of a picture editing program is unavoidable...
velocity90
Ok, im not skilled with those. I will fly them as they are :)
Is the bright red/yellow one also coming?
http://t1.gstatic.com/images?q=tbn:ANd9 ... 9kB2uhOgHA
Post by JS1 »
Thanks for the input. Maybe I'll add it at a later stage but at the moment too busy with new models :).
... now available for download ...
Thanks to Torsten ...
groovebass
Post by groovebass »
:D Please write me where i can download these GAUI X7, greetings uli
Post by JS1 »
It will be available with HELI-X 5.
Then you can download/update it anytime from within the Sim using the "Look for new helicopters" menu item.
