No controller (again)
Re: No controller (again)
Are there any exceptions visible in the console window or the log file?
jonluk
Post by jonluk »
Console shows:
at net.java.games.input.LinuxEnvironmentPlugin.enumerateJoystickControllers(LinuxEnvironmentPlugin.java:406)
at net.java.games.input.LinuxEnvironmentPlugin.enumerateControllers(LinuxEnvironmentPlugin.java:233)
at net.java.games.input.LinuxEnvironmentPlugin.<init>(LinuxEnvironmentPlugin.java:113)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
at java.lang.Class.newInstance0(Class.java:355)
at java.lang.Class.newInstance(Class.java:308)
at net.java.games.input.DefaultControllerEnvironment.getControllers(DefaultControllerEnvironment.java:157)
at ch.ntb.HeliX.controller.FlightController.<init>(FlightController.java:86)
at ch.ntb.HeliX.simulation.Simulation.initController(Simulation.java:164)
at ch.ntb.HeliX.application.Application.<init>(Application.java:153)
at ch.ntb.HeliX.application.Application$1.run(Application.java:757)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:273)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:183)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:173)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:168)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:160)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:121)
Log file:
Application started
3D Environment created
Found 11 display modes
Using display mode 800x600x?x?
Scenegraph created
Listener Volume: 1.0
Listener Volume: 0.8
Sound configuration read
View initialized
Environment initialized
Loading: net.java.games.input.LinuxEnvironmentPlugin
No Joystick found
Trying to open xml File ressources/environments/SkyBox/Small/Small.xml
Environment loaded
Loading ressources/models/helicopter/Lama/Lama.obj
Creating Sound ressources/models/helicopter/Lama/Lama.wav
Sound ressources/models/helicopter/Lama/Lama.wav created
Creating Sound ressources/miscellaneous/crash.wav
Sound ressources/miscellaneous/crash.wav created
Key listener added
Status line added
Visible set true
Keyboard and mouse registered
Stopping HELI-X
Just upgrade my kernel to 2.6.26 to see if that made any difference but it didn't....
Did you get the same error in the Joystick tool? The unsatisfied Link is strange...
jonluk
Post by jonluk »
If by joystick tool you mean the Analizer then no it just worked straight away.
jonluk
Post by jonluk »
Hi Michael,
I've fixed it.
There was a bit in this thread viewtopic.php?f=9&t=9&st=0&sk=t&sd=a&start=10 about downloading the newest jinput libraries. I put the new libjinput-linux.so into the relevant heli-x directory and bingo it's up and running.
YIPEE :) :) :) at last a sim that I can run :)
interesting. Could you please tell me,
1. When you downloaded your version of HELI-X
2. Where you got the libjinput-linix.so which works.
Thanks,
jonluk
Post by jonluk »
My copy of heli-x on 7th Oct.
I got the latest jinput binaries from https://jinput.dev.java.net/servlets/Pr ... entList%3b - there's a link called 'Latest jinput binaries'.
Thanks, I will check this.
thomas_e
Post by thomas_e »
Hi Michael,
hatte das gleiche Problem und nach Austausch der libjinput-linux.so funktionierts bei mir :-)
Was mir bei der Problemanalyse noch aufgefallen war, sind die "merkwürdigen" Zeichen hinterm ControllerNamen.
Sowohl Linux, als auch Windows scheinen da ein Darstellungsproblem zu haben.
Es wird wohl ein Stick aus China sein ;-)
Joystick-Analyzer (by Michael Schreiner)
Linux plugin claims to have found 8 controllers
Controller: ? PPM
Type: Stick
Digital component found:Thumb
Analog component found:x
Analog component found:y
Analog component found:z
Analog component found:rx
Analog component found:ry
mfg
thomas_e
Hallo Thomas,
danke. Was für ein Linux-System hast Du?
