kein Joystick
mh75
Re: kein Joystick
Post by mh75 »
Hallo Rainer
Bus 003 Device 004: ID 0402:0402 ALi Corp.
diese Zeile taucht auf, wenn das usb interface angesteckt ist.
Sonst nix!
Gruß Markus
Re: kein Joystick
ich bin noch hier dran:
Darum versuch mal folgendes:
sudo chmod 777 /dev/input/e*
Dann tippe
ls -l /dev/input
Und zeige uns die Ausgabe.
Dann starte HELI-X. Wenn es nicht geht, zeige uns das Logfile.
mh75
Re: kein Joystick
Post by mh75 »
Hallo Michael.
hat leider nicht funktioniert.
ergebniss von ls -l /dev/input
rwxr-xr-x  2 root root    140 2009-08-08 08:56 by-id
drwxr-xr-x  2 root root    160 2009-08-08 08:56 by-path
crwxrwxrwx  1 root root 13, 64 2009-08-08 10:56 event0
crwxrwxrwx  1 root root 13, 65 2009-08-08 10:56 event1
crwxrwxrwx+ 1 root root 13, 66 2009-08-08 10:56 event2
crwxrwxrwx+ 1 root root 13, 67 2009-08-08 08:56 event3
crwxrwxrwx  1 root root 13, 68 2009-08-08 08:56 event4
crwxrwxrwx  1 root root 13, 69 2009-08-08 08:56 event5
crwxrwxrwx+ 1 root root 13, 70 2009-08-08 08:56 event6
crw-r-----  1 root root 13, 63 2009-08-08 10:56 mice
crw-r-----  1 root root 13, 32 2009-08-08 10:56 mouse0
crw-r-----  1 root root 13, 33 2009-08-08 08:56 mouse1
crw-r-----  1 root root 13, 34 2009-08-08 08:56 mouse2
log file von Heli-x
Set new path for the resources: /home/markus/heli/HELI-X/resources/
Set new path for the user files: /home/markus/heli/HELI-X/files/
Found 59 display modes
Linux plugin claims to have found 6 controllers
No Joystick found
linux logfile:
Aug  8 09:02:34 polarstation kernel: [  373.148012] usb 6-1: new low speed USB device using uhci_hcd and address 2
Aug  8 09:02:34 polarstation kernel: [  373.303307] usb 6-1: configuration #1 chosen from 1 choice
Aug  8 09:02:34 polarstation kernel: [  373.341075] input: HID 0402:0402 as /devices/pci0000:00/0000:00:1d.0/usb6/6-1/6-1:1.0/input/input7
Aug  8 09:02:34 polarstation kernel: [  373.344989] generic-usb 0003:0402:0402.0004: input,hidraw3: USB HID v1.00 Joystick [HID 0402:0402] on usb-0000:00:1d.0-1/input0
Aug  8 09:04:46 polarstation kernel: [  505.592227] usb 6-1: USB disconnect, address 2
So, das wars.
Gruß Markus
Re: kein Joystick
Da sind wir doch schon mal ein Stück weiter.
Zuvor gab es ja viele Fehlermeldungen "Unable to open device", jetzt nur noch eine für event7. Das ist auch bei der Liste aus dem ls-Befehl nicht dabei. Offnebar wurde es neu erzeugt und hat wohl noch die falschen Rechte.
Also bitte aus diese Situation:
ls ...
sudo chmod ...
ls ...
HELI-X starten
Was sagt das Logfile
Eventuell noch einmal wiederholen ab den ersten ls ...
mh75
Re: kein Joystick
Post by mh75 »
hallo,
leider noch nicht besser!
drwxr-xr-x  2 root root    180 2009-08-08 14:01 by-id
drwxr-xr-x  2 root root    200 2009-08-08 14:01 by-path
crwxrwxrwx  1 root root 13, 71 2009-08-08 14:01 event7
crw-r--r--  1 root root 13,  0 2009-08-08 14:01 js0
linux:
Aug  8 13:57:51 polarstation kernel: [ 2191.984009] usb 3-1: new low speed USB device using uhci_hcd and address 2
Aug  8 13:57:51 polarstation kernel: [ 2192.138306] usb 3-1: configuration #1 chosen from 1 choice
Aug  8 13:57:51 polarstation kernel: [ 2192.158077] input: HID 0402:0402 as /devices/pci0000:00/0000:00:1a.0/usb3/3-1/3-1:1.0/input/input8
Aug  8 13:57:51 polarstation kernel: [ 2192.164668] generic-usb 0003:0402:0402.0005: input,hidraw3: USB HID v1.00 Joystick [HID 0402:0402] on usb-0000:00:1a.0-1/input0
Aug  8 14:01:05 polarstation kernel: [ 2385.680050] usb 3-1: USB disconnect, address 2
Aug  8 14:01:14 polarstation pulseaudio[6379]: pid.c: Stale PID file, overwriting.
Aug  8 14:01:58 polarstation kernel: [ 2439.440013] usb 3-1: new low speed USB device using uhci_hcd and address 3
Aug  8 14:01:58 polarstation kernel: [ 2439.594292] usb 3-1: configuration #1 chosen from 1 choice
Aug  8 14:01:58 polarstation kernel: [ 2439.626078] input: HID 0402:0402 as /devices/pci0000:00/0000:00:1a.0/usb3/3-1/3-1:1.0/input/input9
Aug  8 14:01:58 polarstation kernel: [ 2439.632357] generic-usb 0003:0402:0402.0006: input,hidraw3: USB HID v1.00 Joystick [HID 0402:0402] on usb-0000:00:1a.0-1/input0
Gruß Markus
Re: kein Joystick
... mich interessiert jetzt eher das Logfile von HELI-X, worüber sie sich beschwert.
mh75
Re: kein Joystick
Post by mh75 »
sorry...
da isse...
No Joystick found
Gruß Markus
Re: kein Joystick
Damit sind die Fehlermeldungen von HELI-X weg. Trotzdem erkennt er die Hardware nicht als Joystick. Es ist denkbar, dass der Controller als etwas anderes erkannt wird. Versuch mal, mit den JoytickAnalyzer die Sache zu durchleuchten:
viewtopic.php?f=5&t=48&p=195&hilit=joys ... lyzer#p195
RainerS
Re: kein Joystick
Post by RainerS »
ich glaube, dein USB Interface erzeugt den /dev/input/js0 eingang.
Man müsste jetzt mal einen Symlink darauf erzeugen, da Heli_x scheinbar die nicht abfragt, oder Michael?
Symlink erzeugen mit:
sudo ln -s /dev/input/js0 /dev/input/event8
ggf. die Rechte von js0 noch ändern
sudo chmod 777 /dev/input/js0
und
Probiere das mal.
Rainer
Re: kein Joystick
Bei Markus läuft auch der JoystickAnalyzer nicht. Komische Sache.
