Inacceptable Stick Movement Delay
Poldi
Re: Inacceptable Stick Movement Delay
Post by Poldi »
I tried 2x and off settings without signficant effect.
@Poldi: describe your PC system - CPU? Graphics card? Driver version? Main and graphics memory size?
Poldi
Post by Poldi »
Lenovo Yoga 2 1051L
Intel atom cpu z3745 1,33GHz
graphics card intel HD graphics
Codename Bay Trail
Architektur Ivy Bridge
Pipelines 4 - unified
Kerntakt * 311 - 896 (Boost) MHz
Speicherbandbreite 32/64/128 Bit
Shared Memory ja
DirectX DirectX 11, Shader 5.0
I hope this support some diagnosis?
Regards,
Poldi
In fact there's not much information available about the graphics chipset. I have an older Atom-netbook and the graphics performance is really low, only Heli-X v4 runs smooth enough to be usable there. I also have to choose a low detail helicopter model. Can you tell a bit more exactly what graphics chipset the 1051 has? Use e.g. GPU-Z (http://www.gpu-z.de/) or CPU-Z (http://www.cpuid.com/softwares/cpu-z.html) to find out
Poldi
Post by Poldi »
Poldi
Post by Poldi »
Poldi
Post by Poldi »
Thanks to Thomas, again.
Sorry for these awkward posts, trying hard to bring the needed information up.
Regards,
Poldi
Hello poldi,
as already suspected, your graphics chipset's performance seems too low. I only found a german review, but like the GMA945 in my Atom netbook yours seems to be a chipset optimized for 2D -> smooth video playback. Try Heli-X v4 and see if performance is better. You may also try to run some 3D benchmark yourself. And please don't see it too negative - I have seen more than one notebook's graphics chip being destroyed by too much heat. With the Intel solution this surely won't happen.
Have success...
Poldi
Post by Poldi »
Hello Thomas,
that is a pity. I surely did not purchase this tablet as a graphics gaming engine, however, I was thinking it would have enough umpf since it is an actual design...
I will go try for version 4. What am I missing with respect to version 6?
Thanks for all diagnosis,
Poldi
Poldi wrote:Hello Thomas,
Quite a difference I must admit. Smooth shadows are missing for example. v4 has different airports and different models (quite a lot!!). The thing that annoys most is not a Heli-X problem, though: small screen size of your notebook, as 11 inches is really small for simulation purposes (do you have an external monitor??).
Have success :)
