Use 5 channels not available
watlip
Post by watlip » 18 Nov 2016 13:06
I am using a USB adapter bought from Ebay (http://www.ebay.co.uk/itm/261173295142? ... EBIDX%3AIT) and a Spektrum DX8 transmitter.
When I select Controller Configuration everything is OK apart from I cannot select teh Use 5 channels option. It is shown but doesn't do anything if I click on in.
The helis fly OK, but use the Collective control for throttle input.
Any ideas how to enable this option please?
Re: Use 5 channels not available
Post by Michael » 18 Nov 2016 22:50
Hello
1. Does your interface transmit 5 channels?
2. Did you move ALL 5 channels at the beginning of the calibration process?
Devil
Post by Devil » 18 Nov 2016 23:01
Ich tippe mal drauf dass dieses Interface lediglich 4 Kanäle unterstützt. Mit meiner DX18 funktionieren an so einem Modul auch nur vier Kanäle.
watlip
Post by watlip » 19 Nov 2016 12:40
Vielen Dank. Ich denke, das muss das Problem sein.
Kann mir jemand eine gute 5-Kanal-USB-Schnittstelle empfehlen?
Can anyone recommend a good 5 channel USB interface please?
