Anybody has Heli-x running on Windows 10 (64bit) ?
It doesn't seem to continue after the language selection.
Thanks
Best regards
Christophe
Heli-x on Windows 10
Re: Heli-x on Windows 10
It is likely that you do not have the correct driver for your graphics adapter. Download it from the vendor's web site.
Any output in the console window?
Because of older graphic card, V6 is not working. V4 works.
Thanks
Best regards
Christophe
Thanks
Best regards
Christophe
Same problem here. After updating to Windows 10, Heli-X V6 doesn't work any longer. I reinstalled Heli-X, Java and the display driver for Geeforce 310M aswell but it didn't fix the issue. After selecting the language, the console window closes.
On Windows 7 everything was fine.
You need to find a graphics driver supporting openGL.
RolfHeller
i 'd like to use Heli-X V6 in a Windows 10 64k-environment. I' m getting the following answer, when starting heli-x from the command-line:
C:\HELI-X6>Java\jre8\bin\java.exe -Djava.library.path=. -Xms512m -classpath ./libs/HeliX/HeliX6.jar;./libs/HeliX/Translation.jar;./libs/HeliX/Media.jar;./libs/jme/jME3-core.jar;./libs/jme/jME3-plugins.jar;./libs/jme/jME3-terrain.jar;./libs/jme/jME3-desktop.jar;./libs/jme/jME3-blender.jar;./libs/jme/jME3-jogg.jar;./libs/jme/jME3-lwjgl.jar;./libs/jme/jME3-effects.jar;./libs/jme/eventbus.jar;./libs/jme/lwjgl.jar;./libs/jme/nifty.jar;./libs/jme/jME3-niftygui.jar;./libs/jme/xmlpull-xpp3.jar;./libs/jme/joal.jar;./libs/jme/jinput.jar;./libs/jdom/jdom.jar;./libs/javagamenetworking/jgn.jar;./libs/math/openmali.jar;./libs/jme/gluegen-rt.jar;./libs/jme/j-ogg-oggd.jar;./libs/jme/j-ogg-vorbisd.jar;./libs/jme/styles.zip;./libs/jme/nifty-default-controls.jar;./libs/jme/nifty-style-black.jar HELIX
handleError
SCHWERWIEGEND b 12:24:03 Failed to create display
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:252)
at org.lwjgl.opengl.Display.createWindow(Display.java:306)
at org.lwjgl.opengl.Display.create(Display.java:848)
at org.lwjgl.opengl.Display.create(Display.java:757)
at com.jme3.system.lwjgl.LwjglDisplay.createContext(LwjglDisplay.java:140)
at com.jme3.system.lwjgl.LwjglAbstractDisplay.initInThread(LwjglAbstractDisplay.java:113)
at com.jme3.system.lwjgl.LwjglAbstractDisplay.run(LwjglAbstractDisplay.java:207)
C:\HELI-X6>rem If you want to configure the proxy server manually, use this:
C:\HELI-X6>rem Java\jre8\bin\java.exe -Dsun.java2d.noddraw=true -Dhttp.proxyHost=<PROXY_NAME_OR_IP> -Dhttp.proxyPort=<PROXY_PORT> -Djava.library.path=. -Xms512m -classpath ./libs/HeliX/HeliX6.jar;./libs/HeliX/Translation.jar;./libs/HeliX/Media.jar;./libs/jme/jME3-core.jar;./libs/jme/jME3-plugins.jar;./libs/jme/jME3-terrain.jar;./libs/jme/jME3-desktop.jar;./libs/jme/jME3-blender.jar;./libs/jme/jME3-jogg.jar;./libs/jme/jME3-lwjgl.jar;./libs/jme/jME3-effects.jar;./libs/jme/eventbus.jar;./libs/jme/lwjgl.jar;./libs/jme/nifty.jar;./libs/jme/jME3-niftygui.jar;./libs/jme/xmlpull-xpp3.jar;./libs/jme/joal.jar;./libs/jme/jinput.jar;./libs/jdom/jdom.jar;./libs/javagamenetworking/jgn.jar;./libs/math/openmali.jar;./libs/jme/gluegen-rt.jar;./libs/jme/j-ogg-oggd.jar;./libs/jme/j-ogg-
and the following message is displayed:
Failed to create Display
Does it show that OpenGL is lacking?
The graphics-card from "ATI Radeon HD 4600 Series" is run with an actual Microsoft PNP-Monitor (Standard)-driver. The monitor is HannsG HW191D.
Any idears?
handleError
Any idears?
Glück auf!
Rolf
Rolf
RolfHeller
Hey,
I inplemented a new graphics card and Heli-x starts.
Rolf
Rolf
Glück auf!
Rolf
Rolf
