gamepad console
fr3d
gamepad console
Post by fr3d »
is it possible to use a gaming console like a xbox controller to run the sim?
Re: gamepad console
from the software it should work, but the resolution is so bad that it does not make sense...
Sky Slicer
Re: gamepad console
Post by Sky Slicer »
I have used the LogiTech Gamepad F310 successfully. You can go into the Flight Mode settings and reduce the sensitivity around zero (Exp 60%). However, the collective/throttle (up and down om the left stick) is unnatural because it is spring-loaded to the center. Not that bad though.
