Help
Re: Help
Hi.
Well, the most obvious thing would be that you have CCPM mixing (or some other mixing) still enabled in your radio.
So, throttle (more like pitch) controls all three (or four) swash servos, causing an interaction if you intend to have separate channels for each.
A clean model memory with H-1 (mechnical mixing) or a simple fixed-wing programme would be a start in your radio.
Cheers
Eddi
Cheers
Eddi
