Heli-X6 for Linux using 32-bit libraries - Slowness ensues
Posted: 25 Jul 2015 21:56
by Dralan
I've been using Heli-X41 (paid version) for many years now on Linux, and it works great. My system is by no means slow:
2600k, 16GB dual channel memory, two Nvidia 580 GTX cards running SLI with the Nvidia Driver (opengl works fine, and I play games in steam without issue).
A few days ago, I tried to use Heli-X6, and immediately had issues. First, I noticed that the old dual library option was gone, and instead of having separate scripts to load run time libraries for 32-bit and 64-bit compilations, there is only a single script to start Heli-X.
From Heli-X41:
./libs/gluegen/linux-i586/libgluegen-rt.so
./libs/gluegen/linux-amd64/libgluegen-rt.so
./libs/jinput_old/linux-i586/libjinput-linux.so
./libs/jinput_old/linux-amd64/libjinput-linux64.so
./libs/joal/linux-i586/libopenal.so
./libs/joal/linux-i586/libjoal_native.so
./libs/joal/linux-amd64/libopenal.so
./libs/joal/linux-amd64/libjoal_native.so
./libs/lwjgl/linux-i586/liblwjgl.so
./libs/lwjgl/linux-amd64/liblwjgl64.so
./libs/jinput/linux-i586/libjinput-linux.so
./libs/jinput/linux-amd64/libjinput-linux64.so
./libs/jogl/linux-i586/libjogl.so
./libs/jogl/linux-i586/libjogl_cg.so
./libs/jogl/linux-i586/libjogl_drihack.so
./libs/jogl/linux-i586/libjogl_awt.so
./libs/jogl/linux-amd64/libjogl.so
./libs/jogl/linux-amd64/libjogl_cg.so
./libs/jogl/linux-amd64/libjogl_awt.so
From Heli-X6:
libjinput-linux64.so: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=59e779dc7019bb3d4dcff5bd6be7e8cc9cb37ebe, stripped
libjinput-linux.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, BuildID[sha1]=4fb5e1fbbfba0a937f53c3e1379b0805f4569c07, stripped
liblwjgl64.so: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=79aea5a6f9402a4197f8d76c333a5b8c671ba11e, stripped
liblwjgl.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, BuildID[sha1]=2f476eda4eb53baad0dc4a3d72e5812c7bb06f25, stripped
libopenal64.so: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, BuildID[sha1]=cd6f23c3576be4bba86264d3fc2be378e15596a6, not stripped
libopenal.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, BuildID[sha1]=14c3264f900f71fad221f4a49c81406c4bb29a26, not stripped
When I try to use the launcher provided, runHELI-X.sh, it tries to load the 32-bit libraries, and causes problems:
OpenJDK 64-Bit Server VM warning: You have loaded library /home/dralan/games/HELI-X6/libjinput-linux.so which might have disabled stack guard. The VM will try to fix the stack guard now.
After that, the menus are sluggish, and I only get 5FPS in the game no matter what video options I try or what resolution I run at. Heli-X41 worked fine, and I could get hundreds of frames per seconds on my machine.
How do I tell it to load the 64-bit libraries?
Re: Heli-X6 for Linux using 32-bit libraries - Slowness ensu
Posted: 27 Jul 2015 21:51
please make sure that the 64 bit java is in your path. Then, the 64 bit libs should be loaded automatically. The Sun java is usually better the openJDK.
Posted: 28 Jul 2015 05:13
by Dralan
I had actually already tried it with:
openjdk version "1.8.0_45"
OpenJDK Runtime Environment (build 1.8.0_45-b14)
OpenJDK 64-Bit Server VM (build 25.45-b02, mixed mode)
and with:
java version "1.8.0_51"
Java(TM) SE Runtime Environment (build 1.8.0_51-b16)
Java HotSpot(TM) 64-Bit Server VM (build 25.51-b03, mixed mode)
Is there some way I can force this to run in 64-bit mode? I don't even have 32-bit java installed on my system.
Posted: 28 Jul 2015 07:31
... the default resolutions of the airports changed from 4.1 to higher versions. Please load an airport of type SkyBox1024
Posted: 01 Aug 2015 01:36
by Dralan
I have updated all of the helicopters and all of the airports. I have also solved the library problem / jvm warning, but the slowness persists with some bugs.
Here's what I did to fix the JVM issue:
I deleted all 32-bit .so libraries and symlinked the 64-bit libraries to their old names.
I ran ldd on all libraries and found that it was using a mix and mash of java libraries, which I fixed by setting the environment variable LD_LIBRARY_PATH=/usr/java/latest/lib/amd64/:/usr/java/latest/lib/amd64/server/. Now I get the following:
linux-vdso.so.1 (0x00007ffe861fa000)
libc.so.6 => /lib64/libc.so.6 (0x00007fd9d8512000)
/lib64/ld-linux-x86-64.so.2 (0x00007fd9d8aee000)
liblwjgl64.so:
linux-vdso.so.1 (0x00007ffca56cc000)
libm.so.6 => /lib64/libm.so.6 (0x00007f6d6d19f000)
libX11.so.6 => /usr/lib64/libX11.so.6 (0x00007f6d6ce60000)
libXext.so.6 => /usr/lib64/libXext.so.6 (0x00007f6d6cc4e000)
libXcursor.so.1 => /usr/lib64/libXcursor.so.1 (0x00007f6d6ca43000)
libXrandr.so.2 => /usr/lib64/libXrandr.so.2 (0x00007f6d6c838000)
libXxf86vm.so.1 => /usr/lib64/libXxf86vm.so.1 (0x00007f6d6c632000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f6d6c415000)
libjawt.so => /usr/java/latest/lib/amd64/libjawt.so (0x00007f6d6c213000)
libc.so.6 => /lib64/libc.so.6 (0x00007f6d6be6c000)
libxcb.so.1 => /usr/lib64/libxcb.so.1 (0x00007f6d6bc4c000)
libdl.so.2 => /lib64/libdl.so.2 (0x00007f6d6ba47000)
libXrender.so.1 => /usr/lib64/libXrender.so.1 (0x00007f6d6b83d000)
libXfixes.so.3 => /usr/lib64/libXfixes.so.3 (0x00007f6d6b637000)
/lib64/ld-linux-x86-64.so.2 (0x00007f6d6d73f000)
libawt.so => /usr/java/latest/lib/amd64/libawt.so (0x00007f6d6b364000)
libawt_xawt.so => /usr/java/latest/lib/amd64/libawt_xawt.so (0x00007f6d6b10b000)
libjava.so => /usr/java/latest/lib/amd64/libjava.so (0x00007f6d6aedf000)
libjvm.so => /usr/java/latest/lib/amd64/server/libjvm.so (0x00007f6d69f15000)
libXau.so.6 => /usr/lib64/libXau.so.6 (0x00007f6d69d11000)
libXtst.so.6 => /usr/lib64/libXtst.so.6 (0x00007f6d69b0a000)
libXi.so.6 => /usr/lib64/libXi.so.6 (0x00007f6d698fa000)
libverify.so => /usr/java/latest/lib/amd64/libverify.so (0x00007f6d696eb000)
libopenal64.so:
linux-vdso.so.1 (0x00007ffd2f547000)
librt.so.1 => /lib64/librt.so.1 (0x00007f9da99e4000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f9da97c6000)
libdl.so.2 => /lib64/libdl.so.2 (0x00007f9da95c2000)
libm.so.6 => /lib64/libm.so.6 (0x00007f9da92c1000)
libc.so.6 => /lib64/libc.so.6 (0x00007f9da8f19000)
/lib64/ld-linux-x86-64.so.2 (0x00007f9da9e76000)
Now all of the warning messages have gone away, and I think it's safe to say it is using Oracle/Sun's java, and not openJDK.
I still have slowness issues, but they are strange. I will see a white tile overhead. If the helicopter is on the ground, or if it is above eye level, I get a solid 5 FPS. If the helicopter is eye level, it suddenly speeds up to my vsync rate of 60 FPS. I think perhaps that something is not working well with my NVidia driver? I am able to play fullscreen opengl games at 1080p with max FPS with vsync enabled. I tried disabling vsync and it made no difference. Are there any other suggestions? I am running out of ideas.
Also of note, even the menus are extremely sluggish.
Posted: 01 Aug 2015 01:47
by Dralan
I figured it out. It was actually shadows. I disabled shadows and am able to play the simulator with otherwise very heavy settings and it runs smoothly. I guess I'll have to turn on the shadow options one by one to see which one is causing the problem, but at least I can fly with the new version. 5FPS is simply not flyable.
