Null Spatial Name Bug in 6.0.1612 on Linux
Posted: 12 May 2015 04:59
While using HELI-X with view zoomed, crash and retry training enabled, status line shown, and slow motion set to about 50%, my screen started flashing after a heli crash.
Looking at the console which started HELI-X, I see the following error:
Hope that helps.
Thanks,
-B
State was changed after rootNode.updateGeometricState() call.
Make sure you do not modify the scene from another thread!
Problem spatial name: null
at com.jme3.scene.Spatial.checkCulling(Spatial.java:260)
at com.jme3.renderer.RenderManager.renderSubScene(RenderManager.java:647)
at com.jme3.renderer.RenderManager.renderScene(RenderManager.java:640)
at com.jme3.renderer.RenderManager.renderViewPort(RenderManager.java:974)
at com.jme3.renderer.RenderManager.render(RenderManager.java:1023)
at net.HeliX.j.j.update(Unknown Source)
at net.HeliX.j.b.update(Unknown Source)
at com.jme3.system.lwjgl.LwjglAbstractDisplay.runLoop(LwjglAbstractDisplay.java:151)
at com.jme3.system.lwjgl.LwjglDisplay.runLoop(LwjglDisplay.java:185)
at com.jme3.system.lwjgl.LwjglAbstractDisplay.run(LwjglAbstractDisplay.java:228)
java.lang.IllegalStateException: Scene graph is not properly updated for rendering.
$ java -version
java version "1.7.0_79"
OpenJDK Runtime Environment (IcedTea 2.5.5) (7u79-2.5.5-1~deb8u1)
OpenJDK 64-Bit Server VM (build 24.79-b02, mixed mode)
$ uname -a
Linux box 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt9-3~deb8u1 (2015-04-24) x86_64 GNU/Linux
Thanks,
-B
