Joystick in HELI-X5
DrGreenthumb
Joystick in HELI-X5
Post by DrGreenthumb » 25 Jan 2014 15:37
Ich habe gerade die neue Version ausprobiert. Leider funktioniert der Joystick nicht mehr.
In 4.2 gehts. Ich benutze txppm als Treiber.
Wenn ich das tx modul lade werden folgende nods angelegt:
in dev
crw-rw---- 1 root games 222, 0 25. Jan 15:21 tx
in dev/input
crw-rw---- 1 root games 13, 70 25. Jan 15:21 event6
crw-rw---- 1 root games 13, 0 25. Jan 15:21 js0
5 und 4.2 kann ich abwechselnd starten
5 geht nie
4.2 immer
Was hat sich geändert?
Hier noch der Consolenoutput
Set new path for the resources: /mnt/sdb/green/bin/HELI-X42/resources/
Set new path for the user files: /mnt/sdb/green/bin/HELI-X42/files/
Error parsing gtk-icon-sizes string: ''
Found 26 display modes
25.01.2014 15:21:15 net.java.games.input.ControllerEnvironment log
INFO: Failed to open device (/dev/input/event0): Failed to open device /dev/input/event0 (13)
INFO: Failed to open device (/dev/input/event1): Failed to open device /dev/input/event1 (13)
INFO: Failed to open device (/dev/input/event2): Failed to open device /dev/input/event2 (13)
INFO: Failed to open device (/dev/input/event3): Failed to open device /dev/input/event3 (13)
INFO: Failed to open device (/dev/input/event4): Failed to open device /dev/input/event4 (13)
INFO: Failed to open device (/dev/input/event5): Failed to open device /dev/input/event5 (13)
INFO: Linux plugin claims to have found 1 controllers
Controller found: Name: PPM Transmitter(PPM Transmitter)
Using Stick PPM Transmitter
Digital component found:Unknown
Analog component found:x
Analog component found:y
Analog component found:z
Analog component found:slider
Analog component found:rz
Name conflict found for sticks. Using numbers.
Controller configuration file found: /mnt/sdb/green/bin/HELI-X42/files/controller/PPMTransmitter.xml
Controller configuration file /mnt/sdb/green/bin/HELI-X42/files/controller/PPMTransmitter.xml read
