Controller setup, version 7
stefansommer
Post by stefansommer » 10 Feb 2018 13:14
My controller (DX6 and USB cable) works fine in v6.1. In v7, all stick movements seem to be too sensitive in one direction: I get correct input if I set the rates on the transmitter to -100 to +25. If I do the regular controller setup (Configuration->Controller->Stick) without modifying the rate setting on the transmitter, all inputs are much too sensitive in one direction, e.g. cyclic right is too sensitive but not cyclic left.
v.6.1 works just fine with exactly the same setup. Any ideas?
Thanks,
Stefan Sommer
Re: Controller setup, version 7
Post by Michael » 10 Feb 2018 14:08
please try different Input Systems (global options->Controller) and recalibrate afterwards.
stefansommer
Post by stefansommer » 11 Feb 2018 11:38
Thanks, jinput-b1.jar works, the remaining systems have the same problem.
Stefan
