Page 2 of 3
Re: Inacceptable Stick Movement Delay
Posted: 19 Aug 2015 20:58
by Poldi
I tried 2x and off settings without signficant effect.
Posted: 20 Aug 2015 08:02
by ThomasC
@Poldi: describe your PC system - CPU? Graphics card? Driver version? Main and graphics memory size?
Posted: 20 Aug 2015 18:33
by Poldi
Lenovo Yoga 2 1051L
Intel atom cpu z3745 1,33GHz
graphics card intel HD graphics
Codename Bay Trail
Architektur Ivy Bridge
Pipelines 4 - unified
Kerntakt * 311 - 896 (Boost) MHz
Speicherbandbreite 32/64/128 Bit
Shared Memory ja
DirectX DirectX 11, Shader 5.0
I hope this support some diagnosis?
Regards,
Poldi
Posted: 21 Aug 2015 08:56
by ThomasC
In fact there's not much information available about the graphics chipset. I have an older Atom-netbook and the graphics performance is really low, only Heli-X v4 runs smooth enough to be usable there. I also have to choose a low detail helicopter model. Can you tell a bit more exactly what graphics chipset the 1051 has? Use e.g. GPU-Z (
http://www.gpu-z.de/) or CPU-Z (
http://www.cpuid.com/softwares/cpu-z.html) to find out
Posted: 22 Aug 2015 14:53
by Poldi
- CPU.gif (190.51 KiB) Viewed 11700 times
Posted: 22 Aug 2015 14:59
by Poldi
- Memory.gif (47.76 KiB) Viewed 11700 times
- Mainbord.gif (46.19 KiB) Viewed 11700 times
- Graphics.gif (45.01 KiB) Viewed 11700 times
Posted: 22 Aug 2015 15:02
by Poldi
Thanks to Thomas, again.
Sorry for these awkward posts, trying hard to bring the needed information up.
Regards,
Poldi
Posted: 23 Aug 2015 07:49
by ThomasC
Hello poldi,
as already suspected, your graphics chipset's performance seems too low. I only found a german review, but like the GMA945 in my Atom netbook yours seems to be a chipset optimized for 2D -> smooth video playback. Try Heli-X v4 and see if performance is better. You may also try to run some 3D benchmark yourself. And please don't see it too negative - I have seen more than one notebook's graphics chip being destroyed by too much heat. With the Intel solution this surely won't happen.
Have success...
Posted: 23 Aug 2015 08:18
by Poldi
Hello Thomas,
that is a pity. I surely did not purchase this tablet as a graphics gaming engine, however, I was thinking it would have enough umpf since it is an actual design...
I will go try for version 4. What am I missing with respect to version 6?
Thanks for all diagnosis,
Poldi
Posted: 23 Aug 2015 09:12
by ThomasC
Poldi wrote:Hello Thomas,
Quite a difference I must admit. Smooth shadows are missing for example. v4 has different airports and different models (quite a lot!!). The thing that annoys most is not a Heli-X problem, though: small screen size of your notebook, as 11 inches is really small for simulation purposes (do you have an external monitor??).
Have success
